Uboot查看并修改内核设备树节点
FDT命令说明
FDT:flattened device tree 的缩写在 U-Boot 控制台停下后,输入fdt,可以查看fdt命令帮助。
sunxi#fdt
fdt - flattened device tree utility commands
Usage:
fdt addr [-c] <addr> [<length>] - Set the [control] fdt location to <addr>
fdt move <fdt> <newaddr> <length> - Copy the fdt to <addr> and make it active
fdt resize - Resize fdt to size + padding to 4k addr
fdt print <path> [<prop>] - Recursive print starting at <path>
fdt list <path> [<prop>] - Print one level starting at <path>
fdt get value <var> <path> <prop> - Get <property> and store in <var>
fdt get name <var> <path> <index> - Get name of node <index> and store in <var>
fdt get addr <var> <path> <prop> - Get start address of <property> and store in <var>
fdt get size <var> <path> [<prop>] - Get size of [<property>] or num nodes and store in <var>
fdt set <path> <prop> [<val>] - Set <property> [to <val>]
fdt mknode <path> <node> - Create a new node after <path>
fdt rm <path> [<prop>] - Delete the node or <property>
fdt header
fdt bootcpu <id> - Set boot cpuid
fdt memory <addr> <size> - Add/Update memory node
fdt rsvmem print - Show current mem reserves
fdt rsvmem add <addr> <size> - Add a mem reserve
fdt rsvmem delete <index> - Delete a mem reserves
fdt chosen [<start> <end>] - Add/update the /chosen branch in the tree
<start>/<end> - initrd start/end addr
NOTE: Dereference aliases by omiting the leading '/', e.g. fdt print ethernet0。
其中常用的命令就是fdt list 和 fdt set,fdt list 用来查询节点配置,fdt set 用来修改节点配置。
1. 查询配置
首先确定要查询的字段在 device tree 的路径,如果不知道路径,则需要用fdt命令按以下步骤进
行查询。1. 在根目录下查找。
sunxi#fdt list /
model = "{LICHEE_CHIP}";
compatible = "arm,{LICHEE_CHIP}", "arm,{LICHEE_CHIP}";
interrupt-parent = <0x00000001>;
#address-cells = <0x00000002>;
#size-cells = <0x00000002>;
cpuscfg {
ion {
dram {
memory@40000000 {
interrupt-controller@1c81000 {
sunxi-chipid@1c14200 {
timer {
pmu {
dvfs_table {
dramfreq {
gpu@0x01c40000 {
wlan {
bt {
btlpm {
如果找到需要的配置,比如wlan的配置,运行如下命令即可。
sunxi#fdt list /wlan //注意路径中的 /
wlan {
compatible = "allwinner,sunxi-wlan";
clocks = <0x00000096>;
wlan_power = "vcc-wifi";
wlan_io_regulator = "vcc-wifi-io";
wlan_busnum = <0x00000001>;
device_type = "wlan";
wlan_regon = <0x00000077 0x0000000b 0x00000002 0x00000001 0xffffffff 0xffffffff 0
x00000000>;
wlan_hostwake = <0x00000077 0x0000000b 0x00000003 0x00000006 0xffffffff 0xffffffff
0x00000000>;
- 在 soc目录下找。如果在第一步中没有发现要找的配置,比如nand0的配置,则该配置可能在soc目录下。
sunxi#fdt list /soc
soc@01c00000 {
compatible = "simple-bus";
ranges;
device_type = "soc";
hdmi@01ee0000 {
tr@01000000 {
pwm@01c21400 {
nand0@01c03000 {
thermal_sensor {
cpu_budget_cool {
然后用如下命令显示即可:
sunxi#fdt list /soc/nand0
nand0@01c03000 {
compatible = "allwinner,sun50i-nand";
device_type = "nand0";
reg = <0x00000000 0x01c03000 0x00000000 0x00001000>;
interrupts = <0x00000000 0x00000046 0x00000004>;
clocks = <0x00000004 0x0000007e>;
pinctrl-1 = <0x00000081>;
nand0_regulator1 = "vcc-nand";
nand0_regulator2 = "none";
nand0_cache_level = <0x55aaaa55>;
nand0_flush_cache_num = <0x55aaaa55>;
nand0_capacity_level = <0x55aaaa55>;
nand0_id_number_ctl = <0x55aaaa55>;
nand0_print_level = <0x55aaaa55>;
nand0_p0 = <0x55aaaa55>;
nand0_p1 = <0x55aaaa55>;
nand0_p2 = <0x55aaaa55>;
nand0_p3 = <0x55aaaa55>;
status = "disabled";
nand0_support_2ch = <0x00000000>;
pinctrl-0 = <0x000000a9 0x000000aa>;
- 使用路径别名查找。别名是 device tree 中完整路径的一个简写,有一个专门的节点 ( /aliases) 来表示别名的相关信息,用如下命令可以查看系统中别名的配置情况:
sunxi#fdt list /aliases
aliases {
serial0 = "/soc@01c00000/uart@01c28000";
mmc0 = "/soc@01c00000/sdmmc@01c0f000";
mmc2 = "/soc@01c00000/sdmmc@01C11000";
nand0 = "/soc@01c00000/nand0@01c03000";
disp = "/soc@01c00000/disp@01000000";
lcd0 = "/soc@01c00000/lcd0@01c0c000";
hdmi = "/soc@01c00000/hdmi@01ee0000";
pwm = "/soc@01c00000/pwm@01c21400";
boot_disp = "/soc@01c00000/boot_disp";
sunxi#
由于配置了nand0节点的路径别名,因此可以用如下命令来显示nand0的配置信息。
sunxi#fdt list nand0
nand0@01c03000 {
注:在fdt的所有命令中,alias 可以用作path参数。
2. 修改配置
2.1 修改整数配置
命令格式:fdt set path prop 示例:fdt set /wlan wlan_busnum <0x2>
wlan {
status = "disable";
sunxi#fdt set /wlan wlan_busnum <0x2>
wlan {
wlan_busnum = <0x00000002>; //修改后
status = "disable";
注:修改整数时,根据需要也可配置为数组形式,需要用空格来分隔。命令格式:fdt set path prop <0x1 0x2 0x3>
2.2 修改字符串配置
命令格式:fdt set path prop "xxxxx" 示例:fdt set /wlan status "disable"
wlan {
sunxi#fdt set /wlan status "disable"
wlan {
status = "disable"; //修改后
sunxi#
注:修改字符串时,根据需要也可配置为数组形式,需要用空格来分隔。命令格式:fdt set path prop "string1" "string2"
3. GPIO 或者 PIN 配置特殊说明
接口对应的数字编号说明如下:
#define PA 0
#define PB 1
#define PC 2
#define PD 3
#define PE 4
#define PF 5
#define PG 6
#define PH 7
#define PI 8
#define PJ 9
#define PK 10
#define PL 11
#define PM 12
#define PN 13
#define PO 14
#define PP 15
#define default 0xffffffff
Sysconfig 中描述 gpio 的形式如下:Port:端口+组内序号<功能分配><内部电阻状态><驱动能力><输出电平状态>
3.1 PIN 配置说明
Pinctrl 节点分为 cpux 和 cpus,对应的节点路径如下:Cpux : /soc/pinctrl@01c20800 Cpus:/soc/pinctrl@01f02c00
3.2 查看 PIN 配置
PIN 配置属性字段说明:
| 属性字段 | 含义 |
| allwinner,function | 对应于 sysconfig 中的主键名 |
| allwinner,pins | 对应于 sysconfig 中每个 gpio 配置中的端口名 |
| allwinner,pname | 对应于 sysconfig 中主键下面子键名字 |
| allwinner,muxsel | 功能分配 |
| allwinner,pull | 内部电阻状态 |
| allwinner,drive | 驱动能力 |
| allwinner,data | 输出电平状态 |
说明
其中0xffffffff表示使用默认值。
按以下方法查看cpux的 PIN 配置。
sunxi#fdt list /soc/pinctrl@01c20800/lcd0
lcd0@0 {
linux,phandle = <0x000000ab>;
allwinner,pins = "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19", "PD20", "PD21";
allwinner,function = "lcd0";
allwinner,pname = "lcdd0", "lcdd1", "lcdd2", "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7", "lcdd8", "lcdd9";
allwinner,muxsel = <0x00000003>;
allwinner,pull = <0x00000000>;
allwinner,drive = <0xffffffff>;
allwinner,data = <0xffffffff>;
sunxi#
按以下方法查看cpus的 PIN 配置。
sunxi# fdt list /soc/pinctrl@01f02c00/s_uart0
s_uart0@0 {
linux,phandle = <0x000000b4>;
allwinner,pins = "PL2", "PL3";
allwinner,function = "s_uart0";
allwinner,pname = "s_uart0_tx", "s_uart0_rx";
allwinner,muxsel = <0x00000002>;
allwinner,pull = <0xffffffff>;
sunxi#
3.3 修改 PIN 配置
使用fdt set命令可以修改 PIN 中相关属性字段
sunxi#fdt set /soc/pinctrl@01c20800/lcd0 allwinner,drive <0x1>
lcd0@0 {
allwinner,drive = <0x00000001>;
说明
示例中该处修改会影响allwinner,pins表示的所有端口的驱动能力配置,修改allwinner,muxsel, allwinner,pull,allwinner,data的值也会产生类似效果。
3.4 GPIO 配置说明
Device tree 中 GPIO 对应关系,以 usb 中usb_id_gpio为例
sunxi#fdt list /soc/usbc0
usbc0@0 {
test = <0x00000002 0x00000003 0x12345678>;
device_type = "usbc0";
compatible = "allwinner,sun50i-otg-manager";
usb_serial_unique = <0x00000000>;
usb_serial_number = "20080411";
rndis_wceis = <0x00000001>;
usb_id_gpio = <0x00000030 0x00000007 0x00000009 0x00000000 0x00000001 0xffffffff 0xffffffff>;
对应于 device tree 中 usb_id_gpio = <0x00000030 0x00000007 0x00000009 0x00000000 0x00000001 0xffffffff 0xffffffff>,解释如下:
| 属性数值 | 含义 |
| 0x00000030 | device tree 内部一个节点相关信息,这里可以略过 |
| 0x00000007 | 端口 PH, 即 #define PH 7 |
| 0x00000009 | 组内序号, 即 PH09 |
| 0x00000000 | 功能分配, 即将 PH09 配为输入 |
| 0x00000001 | 内部电阻状态, 即配为上拉 |
| 0xffffffff | 驱动能力, 默认值 |
| 0xffffffff | 输出电平, 默认值 |
如果需要修改 usb_id_gpio的配置,可按如下方式(示例修改了驱 动能力,输出电平两项):
sunxi#fdt set /soc/usbc0 usb_id_gpio `<0x00000030 0x00000007 0x00000009 0x00000000 0x00000001 0x2 0x1>`
sunxi#fdt list
usbc0@0 {
usb_id_gpio = <0x00000030 0x00000007 0x00000009 0x00000000 0x00000001 0x00000002 0x00000001>; //修改ok
sunxi#
