开发环境搭建
获取TinaSDK源码
Tina-SDKV2.0源码网盘链接:https://pan.baidu.com/s/13uKlqDXImmMl9cgKc41tZg?pwd=qcw7
上传到ubuntu,创建文件夹用来保存源码:
├── tina-d1-h.tar.bz2.00
├── tina-d1-h.tar.bz2.01
├── tina-d1-h.tar.bz2.02
├── tina-d1-h.tar.bz2.03
├── tina-d1-h.tar.bz2.04
├── tina-d1-h.tar.bz2.05
├── tina-d1-h.tar.bz2.06
├── tina-d1-h.tar.bz2.07
└── tina-d1-h.tar.bz2.08
0 directories, 9 files
查看所有文件MD5校验值:
确保校验值对上。否则需要重新上传。
解压源码:
等待一段时间,即可解压完成。
├── tina-d1-h
1 directory, 9 files
ubuntu@ubuntu1804:~/Tina_SDK$ mv tina-d1-h ../
编译固件之前,先安装一些依赖,否则编译会报错:
编译出固件
进入源码目录,执行source build/envsetup.sh、lunch之后,选择2:
You're building on Linux
Lunch menu... pick a combo:
1. d1-h_nezha_min-tina
2. d1-h_nezha-tina
3. d1s_cvbs-tina
4. d1s_nezha-tina
5. t113_100ask_devkit-tina
6. t113_100ask-tina
Which would you like? [Default d1s_nezha]: 2
TINA_TARGET_ARCH=riscv
TARGET_PRODUCT=d1-h_nezha
TARGET_PLATFORM=d1-h
TARGET_BOARD=d1-h-nezha
TARGET_PLAN=nezha
TARGET_BUILD_VARIANT=tina
TARGET_BUILD_TYPE=release
TARGET_KERNEL_VERSION=5.4
TARGET_UBOOT=u-boot-2018
TARGET_CHIP=sun20iw1p1
no buildserver to clean
[1] 66670
接着make编译、pack打包:
make[5]: Leaving directory '/home/ubuntu/tina-d1-h/target/allwinner/generic/image'
make[4]: Leaving directory '/home/ubuntu/tina-d1-h/target/allwinner/d1-h-nezha'
make[3]: Leaving directory '/home/ubuntu/tina-d1-h/target/allwinner'
make[2]: Leaving directory '/home/ubuntu/tina-d1-h'
export MAKEFLAGS= ;make -w -r package/index
make[2]: Entering directory '/home/ubuntu/tina-d1-h'
Generating package index...
Signing key has not been configured
[2]+ Done $T/tools/build/buildserver --path $T 2> /dev/null 1>&2
#### make completed successfully (15:50 (mm:ss)) ####
ubuntu@ubuntu1804:~/tina-d1-h$ ls
build Config.in dl logs out prebuilt rules.mk target toolchain
config device lichee Makefile package README.md scripts tmp tools
PACK_CHIP sun20iw1p1
PACK_PLATFORM tina
PACK_BOARD d1-h-nezha
PACK_KERN
PACK_DEBUG uart0
PACK_SIG none
PACK_SECURE none
PACK_MODE normal
PACK_FUNC android
PACK_PROGRAMMER none
PACK_TAR_IMAGE none
No kernel param, parse it from d1-h
copying tools file
copying configs file
storage_type value is 5
rm /home/ubuntu/tina-d1-h/out/d1-h-nezha/image/sys_partition_nor.fex
rm /home/ubuntu/tina-d1-h/out/d1-h-nezha/image/image_nor.cfg
copying boot resource
copying boot file
make user resource for : /home/ubuntu/tina-d1-h/out/d1-h-nezha/image/sys_partition.fex
handle partition user-res
no user resource partitions
APP_PART_DOWNLOAD_FILE = /home/ubuntu/tina-d1-h/out/d1-h-nezha/image/app.fex
Need size of filesystem
no data resource partitions
don't build dtbo ...
update_chip
pack boot package
content_count=3
packing for tina linux
normal
mbr count = 4
partitation file Path=/home/ubuntu/tina-d1-h/out/d1-h-nezha/image/sys_partition.bin
mbr_name file Path=/home/ubuntu/tina-d1-h/out/d1-h-nezha/image/sunxi_mbr.fex
download_name file Path=/home/ubuntu/tina-d1-h/out/d1-h-nezha/image/dlinfo.fex
mbr size = 252
mbr magic softw411
disk name=boot-resource
disk name=env
disk name=env-redund
disk name=boot
disk name=rootfs
disk name=dsp0
disk name=recovery
this is not a partition key
update_for_part_info 0
crc 0 = 4c7bc2df
crc 1 = d9c69382
crc 2 = bc706624
crc 3 = 29cd3779
gpt_head->header_crc32 = 0x892c53ba
GPT----part num 8---
gpt_entry: 128
gpt_header: 92
GPT:boot-resource: a1f8 c177
GPT:env : c178 c36f
GPT:env-redund : c370 c567
GPT:boot : c568 1161f
GPT:rootfs : 11620 1b597
GPT:dsp0 : 1b598 1b987
GPT:recovery : 1b988 227c7
GPT:UDISK : 227c8 ffffffde
update gpt file ok
update mbr file ok
temp = 20
mbr size = 252
mbr magic softw411
disk name=env
disk name=boot
disk name=rootfs
disk name=dsp0
disk name=recovery
crc 0 = 4c7bc2df
crc 1 = d9c69382
crc 2 = bc706624
crc 3 = 29cd3779
gpt_head->header_crc32 = 0x1328fa28
gpt_entry: 128
gpt_header: 92
GPT:env : c178 c36f
GPT:UDISK : 227c8 e8ffde
update gpt file ok
update mbr file ok
[mbr]
mbr_size : 252 Kbyte
partition_size : 8064
boot-resource.fex size : 3.0M byte
partition_name : env
partition_size : 504
downloadfile : env.fex
env.fex size : 128K byte
partition_name : env-redund
partition_name : boot
partition_size : 20664
downloadfile : boot.fex
boot.fex -> /home/ubuntu/tina-d1-h/out/d1-h-nezha/boot.img
boot.img size : 5.0M byte
partition_name : rootfs
partition_size : 40824
downloadfile : rootfs.fex
rootfs.fex -> /home/ubuntu/tina-d1-h/out/d1-h-nezha/rootfs.img
rootfs.img size : 16M byte
partition_name : dsp0
partition_size : 1008
downloadfile : dsp0.fex
dsp0.fex size : 249K byte
partition_name : recovery
partition_size : 28224
Begin Parse sys_partion.fex
FilePath: boot-resource.fex
FileLength=2f8c00Add partion env.fex ENV_FEX000000000
FilePath: env.fex
FilePath: env.fex
FilePath: boot.fex
FileLength=4f4000Add partion rootfs.fex ROOTFS_FEX000000
FilePath: rootfs.fex
FileLength=fc0000Add partion dsp0.fex DSP0_FEX00000000
Add partion very dsp0.fex DSP0_FEX00000000
FilePath: dsp0.fex
FileLength=3e38cBuildImg 0
/home/ubuntu/tina-d1-h/out/d1-h-nezha/tina_d1-h-nezha_uart0.img
pack finish
打包成功后,镜像文件保存在/home/ubuntu/tina-d1-h/out/d1-h-nezha/tina_d1-h-nezha_uart0.img
烧录固件
把镜像文件传到PC端,打开全志线刷工具 AllwinnertechPhoeniSuit,找到PhoenixSuit.exe ,双击运行:
选择一键刷机:
找到镜像路径,选择全盘擦除升级:
选择 好之后,不需要其他界面操作,这时拿起已经连接好的开发板,先按住 FEL 烧写模式按键,之后按一下 RESET 系统复位键,就可以自动进入烧写模式并开始烧写。
串口打印信息,如下:
[53]HELLO! BOOT0 is starting!
[56]BOOT0 commit : 88480af
[58]set pll start
[60]periph0 has been enabled
[63]set pll end
[64][pmu]: bus read error
[67]board init ok
[69]get_pmu_exist() = -1
[71]DRAM BOOT DRIVE INFO: V0.33
[74]DRAM CLK = 792 MHz
[76]DRAM Type = 3 (2:DDR2,3:DDR3)
[79]DRAMC ZQ value: 0x7b7bfb
[82]DRAM ODT value: 0x42.
[84]ddr_efuse_type: 0x0
[87]DRAM SIZE =512 M
[89]dram_tpr4:0x0
[91]PLL_DDR_CTRL_REG:0xf8004100
[94]DRAM_CLK_REG:0xc0000000
[96][TIMING DEBUG] MR2= 0x18
[100]DRAM simple test OK.
[103]dram size =512
[105]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
[110]block from 8 to 32
[165]Check is correct.
[167]dma 0x301a8 int is not used yet
[171]dma 0x301a8 int is free, you do not need to free it again
[176]Entry_name = opensbi
[179]Entry_name = u-boot
[183]Entry_name = dtb
[186]Jump to second Boot.
OpenSBI auto-t113-linux-V0.8-2-g053d088
____ _____ ____ _____
/ __ \ / ____| _ \_ _|
|_|
Platform Name : T-HEAD Xuantie Platform
Platform HART Features : RV64ACDFIMSUVX
Platform Max HARTs : 1
Current Hart : 0
Firmware Base : 0x41fc0400
Firmware Size : 75 KB
Runtime SBI Version : 0.2
MIDELEG : 0x0000000000000222
MEDELEG : 0x000000000000b1ff
PMP0 : 0x0000000041fc0000-0x0000000041fdffff (A)
PMP1 : 0x0000000040000000-0x000000007fffffff (A,R,W,X)
PMP2 : 0x0000000080000000-0x00000000bfffffff (A,R,W,X)
PMP3 : 0x0000000000020000-0x0000000000027fff (A,▒
U-Boot 2018.05-g24521d6-dirty (Jun 25 2024 - 02:56:26 -0400) Allwinner Technology
[00.271]DRAM: 512 MiB
[00.273]Relocation Offset is: 1dee9000
[00.277]secure enable bit: 0
[00.280]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.286]flash init start
[00.289]workmode = 0,storage type = 0
[00.336]sunxi-spinand-phy: not detect any munufacture from id table
[00.342]sunxi-spinand-phy: get spi-nand Model from fdt fail
[00.348]sunxi-spinand-phy: get phy info from fdt fail
defaults:
mtdids : nand0=nand
[00.462]ubi0: attaching mtd4
[00.557]ubi0: scanning is finished
[00.563]ubi0: attached mtd4 (name "sys", size 123 MiB)
[00.568]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[00.574]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[00.581]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[00.587]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[00.592]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
[00.599]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[00.607]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[00.615]sunxi flash init ok
[00.618]line:703 init_clocks
[00.621]drv_disp_init
request pwm success, pwm0:pwm0:0x2000c00.
[00.638]drv_disp_init finish
[00.640]boot_gui_init:start
[00.643]set disp.dev2_output_type fail. using defval=0
[00.648]lcd_open_flow
[00.650]lcd_cfg_panel_info
[00.653]lcd_open_flow
[00.655]lcd_power_on
[00.680]boot_gui_init:finish
[00.800]lcd_open_flow
[00.802] tft08006 drivers/video/sunxi/disp2/disp/lcd/tft08006.c lcd_panel_init 162
[00.809]lcd_panel_init
[01.283]lcd_open_flow
54 bytes read in 0 ms
[01.288]bmp_name=bootlogo.bmp size 1152054
[01.335]lcd_open_flow
[01.337]lcd_bl_open
[01.350]lcd_open_flow
[01.353]lcd_open_flow
[01.355]LCD open finish
1152054 bytes read in 75 ms (14.6 MiB/s)
[01.491]Loading Environment from SUNXI_FLASH... OK
[01.512]out of usb burn from boot: not need burn key
[01.518]Item0 (Map) magic is bad
[01.544]update bootcmd
[01.556]change working_fdt 0x5eaa8da0 to 0x5ea88da0
[01.584]update dts
noncached_alloc(): addr = 0x5eca7080
noncached_alloc(): addr = 0x5eca70c0
noncached_alloc(): addr = 0x5eca7100
noncached_alloc(): addr = 0x5eca7940
phy_mode=rgmii, phy_interface=7
gmac: *** using ephy_clk ***
eth0
Warning: eth0 (eth0) using random MAC address - 62:2c:14:f8:ee:8c
dsp0:gpio init config fail
dsp0:sharespace config fail
dsp0 version is r528-tina-v1.0.0-release-37-g735b6b4-dirty
DSP0 start ok, img length 254860, booting from 0x400660
[01.901]no vendor_boot partition is found
Android's image name: d1-h-nezha
Detect comp gzip
[02.154]
Starting kernel ...
[ 0.000000] Linux version 5.4.61 (ubuntu@ubuntu1804) (riscv64-unknown-linux-gnu-gcc (C-SKY RISCV Tools V1.8.4 B20200702) 8.1.0, GNU ld (GNU Binutils) 2.32) #50 PREEMPT Tue Jun 25 06:59:32 UTC 2024
[ 0.000000] cma: Reserved 8 MiB at 0x000000005f800000
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] DMA32 zone: 1792 pages used for memmap
[ 0.000000] DMA32 zone: 131072 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129280
[ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/sbin/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:recovery@ubi0_7:rootfs_data@ubi0_8:UDISK@ubi0_9: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun20iw1p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g24521d
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] Memory: 495332K/524288K available (6406K kernel code, 663K rwdata, 2165K rodata, 184K init, 336K bss, 20764K reserved, 8192K cma-reserved)
[ 0.000022] riscv_timer_clockevent depends on broadcast, but no broadcast function available
[ 0.000311] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000911] Console: colour dummy device 80x25
[ 0.000948] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000965] pid_max: default: 32768 minimum: 301
[ 0.001130] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.001150] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.002696] ASID allocator initialised with 65536 entries
[ 0.002847] rcu: Hierarchical SRCU implementation.
[ 0.003453] devtmpfs: initialized
[ 0.016485] random: get_random_u32 called from bucket_table_alloc.isra.31+0x4e/0x15e with crng_init=0
[ 0.017399] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.017429] futex hash table entries: 256 (order: 0, 6144 bytes, linear)
[ 0.017813] pinctrl core: initialized pinctrl subsystem
[ 0.019052] NET: Registered protocol family 16
[ 0.020928] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.021517] cpuidle: using governor menu
[ 0.063906] rtc_ccu: sunxi ccu init OK
[ 0.072980] clock: sunxi ccu init OK
[ 0.073776] clock: sunxi ccu init OK
[ 0.102457] iommu: Default domain type: Translated
[ 0.102628] sunxi iommu: irq = 4
[ 0.103675] SCSI subsystem initialized
[ 0.103996] usbcore: registered new interface driver usbfs
[ 0.104089] usbcore: registered new interface driver hub
[ 0.104190] usbcore: registered new device driver usb
[ 0.104349] mc: Linux media interface: v0.10
[ 0.104405] videodev: Linux video capture interface: v2.00
[ 0.105459] sunxi-msgbox-amp 3003000.msgbox: invalid resource
[ 0.106252] Advanced Linux Sound Architecture Driver Initialized.
[ 0.106819] Bluetooth: Core ver 2.22
[ 0.106894] NET: Registered protocol family 31
[ 0.106905] Bluetooth: HCI device and connection manager initialized
[ 0.106926] Bluetooth: HCI socket layer initialized
[ 0.106940] Bluetooth: L2CAP socket layer initialized
[ 0.106974] Bluetooth: SCO socket layer initialized
[ 0.107245] pwm module init!
[ 0.108757] g2d 5410000.g2d: Adding to iommu group 0
[ 0.109209] G2D: rcq version initialized.major:250
[ 0.109863] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.111373] clocksource: Switched to clocksource riscv_clocksource
[ 0.123010] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 0.137891] thermal_sys: Registered thermal governor 'user_space'
[ 0.137897] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.138388] NET: Registered protocol family 2
[ 0.139140] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.139182] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.139241] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.139288] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.139422] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.139460] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.139672] NET: Registered protocol family 1
[ 0.140824] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.141366] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.141679] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 0.141740] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 0.141752] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 0.141762] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 0.141818] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 0.142463] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base ffffffd004060000, irq 31
[ 0.144302] Initialise system trusted keyrings
[ 0.144493] workingset: timestamp_bits=62 max_order=17 bucket_order=0
[ 0.151060] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.170468] Key type asymmetric registered
[ 0.170482] Asymmetric key parser 'x509' registered
[ 0.170504] io scheduler mq-deadline registered
[ 0.170512] io scheduler kyber registered
[ 0.170531] atomic64_test: passed
[ 0.171741] [DISP]disp_module_init
[ 0.172287] disp 5000000.disp: Adding to iommu group 0
[ 0.172892] [DISP] disp_init,line:2386:
[ 0.172898] smooth display screen:0 type:1 mode:4
[ 0.207628] lcd_cfg_panel_info
[ 0.207639] tft08006
[ 0.207682] display_fb_request,fb_id:0
[ 0.223221] Freeing logo buffer memory: 1500K
[ 0.223650] disp_al_manager_apply ouput_type:1
[ 0.223794] [DISP] lcd_clk_config,line:732:
[ 0.223807] disp 0, clk: pll(300000000),clk(300000000),dclk(25000000) dsi_rate(25000000)
[ 0.223807] clk real:pll(300000000),clk(300000000),dclk(75000000) dsi_rate(150000000)
[ 0.224184] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.224891] [DISP]disp_module_init finish
[ 0.225740] sunxi_sid_init()551 - insmod ok
[ 0.226103] pwm-regulator vdd-cpu: Failed to get PWM: -16
[ 0.226131] pwm-regulator: probe of vdd-cpu failed with error -16
[ 0.232818] uart uart0: get regulator failed
[ 0.232846] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.233177] uart0: ttyS0 at MMIO 0x2500000 (irq = 18, base_baud = 1500000) is a SUNXI
[ 0.233202] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[ 1.063245] printk: console [ttyS0] enabled
[ 1.068808] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.080225] uart uart1: get regulator failed
[ 1.085090] uart uart1: uart1 supply uart not found, using dummy regulator
[ 1.093121] uart1: ttyS1 at MMIO 0x2500400 (irq = 19, base_baud = 1500000) is a SUNXI
[ 1.102998] misc dump reg init
[ 1.107246] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 1.114493] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 1.121855] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 1.129242] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 1.135805] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 1.142741] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 1.150439] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=44 assert=1
[ 1.158229] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 1.166360] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 1.174043] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 1.180762] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 1.188353] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 1.196514] [ADDR_MGT] addr_mgt_probe: module version: v1.0.10
[ 1.204188] [ADDR_MGT] addr_mgt_probe: success.
[ 1.210142] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
[ 1.217408] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.225321] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.232764] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.239385] sunxi-spinand-phy: get phy info from fdt fail
[ 1.245430] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.252110] sunxi-spinand-phy: detect munufacture from id table: Winbond
[ 1.259604] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[ 1.266615] sunxi-spinand-phy: ========== arch info ==========
[ 1.273167] sunxi-spinand-phy: Model: W25N01GVZEIG
[ 1.279863] sunxi-spinand-phy: Munufacture: Winbond
[ 1.286095] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.291772] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.297690] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.303437] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.309081] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.314831] sunxi-spinand-phy: BadBlockFlag: 0x0
[ 1.320652] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.326520] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.332562] sunxi-spinand-phy: EccFlag: 0x0
[ 1.338384] sunxi-spinand-phy: EccType: 2
[ 1.344058] sunxi-spinand-phy: EccProtectedType: 3
[ 1.349687] sunxi-spinand-phy: ========================================
[ 1.357131] sunxi-spinand-phy:
[ 1.360631] sunxi-spinand-phy: ========== physical info ==========
[ 1.367541] sunxi-spinand-phy: TotalSize: 128 M
[ 1.372899] sunxi-spinand-phy: SectorSize: 512 B
[ 1.378254] sunxi-spinand-phy: PageSize: 2 K
[ 1.383422] sunxi-spinand-phy: BlockSize: 128 K
[ 1.388757] sunxi-spinand-phy: OOBSize: 64 B
[ 1.394044] sunxi-spinand-phy: ========================================
[ 1.401440] sunxi-spinand-phy:
[ 1.404936] sunxi-spinand-phy: ========== logical info ==========
[ 1.411772] sunxi-spinand-phy: TotalSize: 128 M
[ 1.417111] sunxi-spinand-phy: SectorSize: 512 B
[ 1.422472] sunxi-spinand-phy: PageSize: 4 K
[ 1.427631] sunxi-spinand-phy: BlockSize: 256 K
[ 1.432992] sunxi-spinand-phy: OOBSize: 128 B
[ 1.438329] sunxi-spinand-phy: ========================================
[ 1.445863] sunxi-spinand-phy: block lock register: 0x00
[ 1.451967] sunxi-spinand-phy: feature register: 0x19
[ 1.457605] sunxi-spinand-phy: sunxi physic nand init end
[ 1.464272] Creating 4 MTD partitions on "sunxi_mtd_nand":
[ 1.470399] 0x000000000000-0x000000100000 : "boot0"
[ 1.482551] 0x000000100000-0x000000500000 : "uboot"
[ 1.490925] random: fast init done
[ 1.512572] 0x000000500000-0x000000600000 : "secure_storage"
[ 1.532519] 0x000000600000-0x000008000000 : "sys"
[ 1.733115] libphy: Fixed MDIO Bus: probed
[ 1.737689] CAN device driver interface
[ 1.743097] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.754440] sunxi gmac driver's version: 1.0.0
[ 1.759554] gmac-power0: NULL
[ 1.762911] gmac-power1: NULL
[ 1.766216] gmac-power2: NULL
[ 1.770656] Failed to alloc md5
[ 1.774250] eth0: Use random mac address
[ 1.778955] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.786363] sunxi-ehci: EHCI SUNXI driver
[ 1.791357] get ehci1-controller wakeup-source is fail.
[ 1.797379] sunxi ehci1-controller don't init wakeup source
[ 1.803712] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xffffffe000962758, 0x:ffffffd00407c000, irq_no:31
[ 1.817272] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
[ 1.829857] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 1.842114] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 1.849334] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 1.859202] sunxi-ehci 4200000.ehci1-controller: irq 49, io mem 0x04200000
[ 1.891419] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 1.899192] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
[ 1.908691] hub 1-0:1.0: USB hub found
[ 1.913001] hub 1-0:1.0: 1 port detected
[ 1.918153] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.925184] sunxi-ohci: OHCI SUNXI driver
[ 1.930181] get ohci1-controller wakeup-source is fail.
[ 1.936194] sunxi ohci1-controller don't init wakeup source
[ 1.942496] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xffffffe0009632b0
[ 1.952932] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
[ 1.965478] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 1.977718] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 1.984975] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 1.994798] sunxi-ohci 4200400.ohci1-controller: irq 50, io mem 0x04200400
[ 2.076326] hub 2-0:1.0: USB hub found
[ 2.080570] hub 2-0:1.0: 1 port detected
[ 2.086001] usbcore: registered new interface driver uas
[ 2.092203] usbcore: registered new interface driver usb-storage
[ 2.098963] usbcore: registered new interface driver ums-alauda
[ 2.105710] usbcore: registered new interface driver ums-cypress
[ 2.112568] usbcore: registered new interface driver ums-datafab
[ 2.119327] usbcore: registered new interface driver ums_eneub6250
[ 2.126371] usbcore: registered new interface driver ums-freecom
[ 2.133353] usbcore: registered new interface driver ums-isd200
[ 2.140017] usbcore: registered new interface driver ums-jumpshot
[ 2.146979] usbcore: registered new interface driver ums-karma
[ 2.153601] usbcore: registered new interface driver ums-onetouch
[ 2.160510] usbcore: registered new interface driver ums-realtek
[ 2.167326] usbcore: registered new interface driver ums-sddr09
[ 2.174035] usbcore: registered new interface driver ums-sddr55
[ 2.180740] usbcore: registered new interface driver ums-usbat
[ 2.187931] sunxi_gpadc_init,2151, success
[ 2.194794] sunxi-rtc 7090000.rtc: registered as rtc0
[ 2.200543] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:01:19 UTC (79)
[ 2.209577] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 2.215667] i2c /dev entries driver
[ 2.219651] IR NEC protocol handler initialized
[ 2.225143] sunxi-rc-recv 7040000.s_cir: sunxi_irrx_resource_get: get ir protocol failed
[ 2.234350] Registered IR keymap rc_map_sunxi
[ 2.239323] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 2.248053] rc rc0: lirc_dev: driver sunxi-rc-recv registered at minor = 0, raw IR receiver, no transmitter
[ 2.259150] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 2.269480] sunxi cedar version 1.1
[ 2.273701] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 2.279972] VE: install start!!!
[ 2.279972]
[ 2.285283] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
[ 2.293018] VE: cedar-ve the get irq is 6
[ 2.293018]
[ 2.299387] VE: ve_debug_proc_info:(____ptrval____), data:(____ptrval____), lock:(____ptrval____)
[ 2.299387]
[ 2.311028] VE: install end!!!
[ 2.311028]
[ 2.316213] VE: sunxi_cedar_probe
[ 2.321557] sunxi-wdt 6011000.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.330746] Bluetooth: HCI UART driver ver 2.3
[ 2.335744] Bluetooth: HCI UART protocol H4 registered
[ 2.341500] Bluetooth: HCI UART protocol BCSP registered
[ 2.347428] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 2.354736] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 2.361079] sun8iw20-pinctrl 2000000.pinctrl: pin PG16 already requested by 7040000.s_cir; cannot claim for 2000000.pinctrl:208
[ 2.373967] sun8iw20-pinctrl 2000000.pinctrl: pin-208 (2000000.pinctrl:208) status -22
[ 2.382857] Bluetooth: can't request bt_wake gpio 208
[ 2.388510] sunxi-btlpm: probe of soc@3000000:btlpm@0 failed with error -22
[ 2.398188] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 2.408192] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 2.414407] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 2.420743] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 2.427178] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 2.433642] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 2.440147] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 2.446673] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 2.453229] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 2.459759] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 2.469497] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.480638] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 2.500857] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.514064] hub 1-1:1.0: USB hub found
[ 2.518457] hub 1-1:1.0: 4 ports detected
[ 2.523012] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 2.530756] sunxi_led_probe()1749 - start
[ 2.535386] sunxi_get_str_of_property()1595 - failed to get the string of propname led_regulator!
[ 2.545326] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[ 2.552447] sunxi_register_led_classdev()1483 - led_classdev start
[ 2.559374] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 52, RTO !!
[ 2.566267] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.583233] sunxi_led_probe()1845 - finish
[ 2.588435] usbcore: registered new interface driver usbhid
[ 2.594848] usbhid: USB HID core driver
[ 2.599290] rpmsg_client_dsp_standby 3003000.msgbox.sunxi,dsp-power-msgbox.512.256: new channel: 0x200 -> 0x100!
[ 2.612043] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.624365] usbcore: registered new interface driver snd-usb-audio
[ 2.633914] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 2.646314] sunxi-daudio 2034000.daudio: regulator missing or invalid
[ 2.653570] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 2.661171] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 2.668032] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:19, mic2gain:19 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 2.668032]
[ 2.685111] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 2.692007] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 2.702900] sunxi-mmc 4021000.sdmmc: smc 0 p1 err, cmd 5, RTO !!
[ 2.709697] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.721345] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[ 2.731246] sid_rd_ver_reg()254 - ver >= 4, soc ver:5
[ 2.737112] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 2.746939] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 2.755719] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 2.772435] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input2
[ 2.784506] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 2.792794] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
[ 2.801241] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
[ 2.810335] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: id:sunxi,dsp-msgbox new channel: 0x202 -> 0x102!
[ 2.821878] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.514.258: rpmsg hifi[0] client driver is probed
[ 2.833780] NET: Registered protocol family 10
[ 2.840125] Segment Routing with IPv6
[ 2.844515] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.851953] NET: Registered protocol family 17
[ 2.856969] can: controller area network core (rev 20170425 abi 9)
[ 2.864076] NET: Registered protocol family 29
[ 2.869041] can: raw protocol (rev 20170425)
[ 2.873834] can: broadcast manager protocol (rev 20170425 t)
[ 2.880177] can: netlink gateway (rev 20190810) max_hops=1
[ 2.886609] Bluetooth: RFCOMM TTY layer initialized
[ 2.892153] Bluetooth: RFCOMM socket layer initialized
[ 2.897933] Bluetooth: RFCOMM ver 1.11
[ 2.903168] Loading compiled-in X.509 certificates
[ 2.910707] HDMI 2.0 driver init start!
[ 2.915106] boot_hdmi=false
[ 2.918286] ERROR: pinctrl_get for HDMI2.0 DDC fail
[ 2.925306] HDMI2.0 module init end
[ 2.954998] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
[ 2.971010] input: fts_ts as /devices/platform/soc@3000000/sunxi-i2c2/i2c-2/2-0038/input/input3
[ 2.981200] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 2.989304] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.021548] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.029148] fts_ts 2-0038: 2-0038 supply not found, using dummy regulator
[ 3.037167] fts_ts 2-0038: 2-0038 supply not found, using dummy regulator
[ 3.044906] debugfs: Directory '2-0038-' with parent 'reg-dummy-regulator-dummy' already present!
[ 3.311557] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.319656] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.361531] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.369612] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.411552] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.419649] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.461544] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.469640] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.511551] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.519649] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.561531] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.569612] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.611550] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.619666] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.661526] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.669625] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.711554] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.719668] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.761527] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.769624] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.811540] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.819636] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.861534] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.869633] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.911566] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.919683] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 3.961530] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 3.969609] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 4.011554] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
[ 4.019653] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x38)
[ 4.061677] sunxi-i2c sunxi-i2c2: probe success
[ 4.070880] debugfs: Directory '2031000.dmic' with parent 'snddmic' already present!
[ 4.081098] sunxi-audio-card 2031060.sounddmic: dmic-hifi <-> 2031000.dmic mapping ok
[ 4.091101] get ehci0-controller wakeup-source is fail.
[ 4.097104] sunxi ehci0-controller don't init wakeup source
[ 4.103362] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xffffffe000962390, 0x:ffffffd004bca000, irq_no:2e
[ 4.116915] [sunxi-ehci0]: Not init ehci0
[ 4.121874] get ohci0-controller wakeup-source is fail.
[ 4.127836] sunxi ohci0-controller don't init wakeup source
[ 4.134116] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xffffffe000962ee8
[ 4.144554] [sunxi-ohci0]: Not init ohci0
[ 4.149457] ubi0: attaching mtd3
[ 4.489346] random: crng init done
[ 4.547059] ubi0: scanning is finished
[ 4.562100] ubi0 warning: ubi_eba_init: cannot reserve enough PEBs for bad PEB handling, reserved 16, need 20
[ 4.575844] ubi0: attached mtd3 (name "sys", size 122 MiB)
[ 4.582007] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[ 4.589699] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[ 4.597310] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 4.605131] ubi0: good PEBs: 488, bad PEBs: 0, corrupted PEBs: 0
[ 4.611868] ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
[ 4.620035] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 4.629372] ubi0: available PEBs: 0, total reserved PEBs: 488, PEBs reserved for bad PEB handling: 16
[ 4.639728] ubi0: background thread "ubi_bgt0d" started, PID 70
[ 4.648304] block ubiblock0_5: created from ubi0:5(rootfs)
[ 4.656347] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.667201] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.674859] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 4.684537] clk: Not disabling unused clocks
[ 4.689329] ALSA device list:
[ 4.692762] cfg80211: failed to load regulatory.db
[ 4.698177] #0: audiocodec
[ 4.701452] #1: snddmic
[ 4.704380] alloc_fd: slot 0 not NULL!
[ 4.712604] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 4.724171] devtmpfs: mounted
[ 4.727648] Freeing unused kernel memory: 184K
[ 4.732686] This architecture does not have kernel memory protection.
[ 4.739896] Run /sbin/init as init process
[ 5.540788] init: Console is alive
[ 5.544987] init: - watchdog -
[ 5.548530] init: - preinit -
[ 6.806363] hdmi_hpd_sys_config_release
/dev/by-name/UDISK already format by ubifs
/dev/by-name/rootfs_data already format by ubifs
[ 6.932034] mount_root: loading kmods from internal overlay
[ 7.178600] block: attempting to load /etc/config/fstab
[ 7.207531] UBIFS (ubi0:9): Mounting in unauthenticated mode
[ 7.214373] UBIFS (ubi0:9): background thread "ubifs_bgt0_9" started, PID 117
[ 7.322289] UBIFS (ubi0:9): recovery needed
[ 7.595009] UBIFS (ubi0:9): recovery completed
[ 7.600582] UBIFS (ubi0:9): UBIFS: mounted UBI device 0, volume 9, name "UDISK"
[ 7.608856] UBIFS (ubi0:9): LEB size: 258048 bytes (252 KiB), min./max. I/O unit sizes: 4096 bytes/4096 bytes
[ 7.619967] UBIFS (ubi0:9): FS size: 53673984 bytes (51 MiB, 208 LEBs), journal size 7741440 bytes (7 MiB, 30 LEBs)
[ 7.631699] UBIFS (ubi0:9): reserved for root: 0 bytes (0 KiB)
[ 7.638207] UBIFS (ubi0:9): media format: w4/r0 (latest is w5/r0), UUID 0F597857-8DF5-4158-BE5D-801B4C610776, small LPT model
[ 7.655206] block: extroot: UUID match (root: 14aa15db-35e00f98-1674d058-b2b76b5f, overlay: 14aa15db-35e00f98-1674d058-b2b76b5f)
[ 7.678473] mount_root: switched to extroot
[ 7.698526] procd: - early -
[ 7.702102] procd: - watchdog -
[ 8.102634] procd: - watchdog -
[ 8.106465] procd: - ubus -
[ 8.110233] procd (1): /proc/128/oom_adj is deprecated, please use /proc/128/oom_score_adj instead.
[ 8.231464]
[ 8.231464] insmod_device_driver
[ 8.231464]
[ 8.238620] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
[ 8.455153] procd: - init -
[ 9.367332] fuse: init (API version 7.31)
[ 9.652921] usbcore: registered new interface driver uvcvideo
[ 9.700342] USB Video Class driver (1.1.1)
[ 9.947238] file system registered
[ 10.136731] configfs-gadget 4100000.udc-controller: failed to start g1: -19
[ 10.584643] read descriptors
[ 10.587868] read strings
[ 10.771638] sunxi_set_cur_vol_work()397 WARN: get power supply failed
[ 10.813963] android_work: sent uevent USB_STATE=CONNECTED
[ 10.970922] sunxi_set_cur_vol_work()397 WARN: get power supply failed
[ 11.032261] configfs-gadget gadget: high-speed config #1: c
[ 11.038600] android_work: sent uevent USB_STATE=CONFIGURED
[ 11.061464] sunxi_vbus_det_work()3356 WARN: get power supply failed
[ 11.081660] android_work: sent uevent USB_STATE=DISCONNECTED
[ 11.639655] android_work: sent uevent USB_STATE=CONNECTED
[ 12.861861] ======== XRADIO WIFI OPEN ========
[ 12.876291] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
[ 12.890370] [XRADIO] Allocated hw_priv @ 000000008a45bbe0
[ 12.911506] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 1
[ 12.927757] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
[ 13.192456] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 13.203999] [XRADIO] Detect SDIO card 1
[ 13.221934] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 13.241446] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 13.267967] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 13.285285] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 13.310972] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 13.331938] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 13.356333] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 13.379484] mmc0: new high speed SDIO card at address 0001
[ 13.398023] [SBUS] XRadio Device:sdio clk=50000000
[ 13.404845] [XRADIO] XRADIO_HW_REV 1.0 detected.
[ 13.512096] [XRADIO] xradio_update_dpllctrl: DPLL_CTRL Sync=0x01400000.
[ 13.585205] [XRADIO] Bootloader complete
[ 13.751601] [XRADIO] Firmware completed.
[ 13.762818] [WSM] Firmware Label:XR_C09.08.52.64_DBG_02.100 2GHZ HT40 Jan 3 2020 13:14:37
[ 13.791479] [XRADIO] Firmware Startup Done.
[ 13.801820] [XRADIO_WRN] enable Multi-Rx!
[ 13.821092] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 13.874500] xt_time: kernel timezone is -0000
[ 13.911779] Error: Driver 'gt9xxnew_ts' is already registered, aborting...
kmodloader done
[ 14.656076] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=00:65:d8:1d:b6:8e
[ 14.681553] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=00:65:d8:1d:b6:8e
[ 14.712564] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
[ 17.264412] libphy: 4500000.eth: probed
[ 17.268701] sunxi-gmac 4500000.eth eth0: No PHY found!
[ 17.564261] libphy: 4500000.eth: probed
[ 17.568578] sunxi-gmac 4500000.eth eth0: No PHY found!
[ 17.602210] sunxi-gmac 4500000.eth eth0: phy init failed
[ 17.626982] br-lan: port 1(eth0) entered blocking state
[ 17.665325] br-lan: port 1(eth0) entered disabled state
[ 17.910180] [SNDCODEC][sunxi_card_hw_params][620]:stream_flag: 0
[ 17.924492] device eth0 entered promiscuous mode
[ 21.976053] [STA_WRN] Freq 2442 (wsm ch: 7) prev: 3.
[ 21.994314] wlan0: authenticate with 94:d9:b3:b7:c9:0a (try 1)
[ 22.007660] [STA_WRN] [HT40][xradio_join_work][bss_ht_info]:
[ 22.007660] [primary_chan :0x00000007]
[ 22.007660] [ht_param :0x0000000f]
[ 22.007660] [operation_mode:0x00000006]
[ 22.007660] [stbc_param :0x00000000]
[ 22.007660] [basic_set[0] :0x00000000]
[ 22.074197] [STA_WRN] [HT40][xradio_join_work][PhyModeCfg:0x0027]
[ 22.074197] [ModemFlags :0x00000007]
[ 22.074197] [ChWidthCfg :0x00000002]
[ 22.074197] [PriChCfg :0x00000000]
[ 22.074197] [BandCfg :0x00000000]
[ 22.074197] [STBC_Enable :0x00000000]
[ 22.074197] [PreambleCfg :0x00000000]
[ 22.074197] [SGI_Enable :0x00000000]
[ 22.074197] GF_Enable :0x00000000]
[ 22.412103] [TXRX_WRN] [RX] IF=0, No key found.
[ 22.514074] wlan0: authenticate with 94:d9:b3:b7:c9:0a (try 2)
[ 22.534240] wlan0: authenticated
[ 22.541050] wlan0: associate with 94:d9:b3:b7:c9:0a (try 1)
[ 22.606343] wlan0: RX AssocResp from 94:d9:b3:b7:c9:0a (capab=0x431 status=0 aid=8)
[ 22.629980] wlan0: associated
[ 22.639652] [AP_WRN] [STA] ASSOC HTCAP 11N 58
[ 22.654007] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x0000000a][HtProtMode:0x0002][Green:0x0004]
[ 22.654455] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x5027]
[ 22.654455] [ModemFlags :0x00000007]
[ 22.654455] [ChWidthCfg :0x00000002]
[ 22.654455] [PriChCfg :0x00000000]
[ 22.654455] [BandCfg :0x00000000]
[ 22.654455] [STBC_Enable :0x00000000]
[ 22.654455] [PreambleCfg :0x00000001]
[ 22.654455] [SGI_Enable :0x00000001]
[ 22.654455] [GF_Enable :0x00000000]
[ 22.815551] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
_____ _ __ _
root@TinaLinux:/#
