Linux 5.15 内核驱动移植
Linux 5.15 内核驱动
下载驱动后获得驱动的 tar.gz
压缩包
解压后找到如下驱动与文件夹
由于 Linux 5.15 需要保证内核的主线化,不可将非主线的第三方驱动放置于内核文件夹中,所以将驱动放置于 bsp
文件夹中。
进入bsp
,找到 bsp/drivers/net/wireless
文件夹中,新建文件夹aic8800
并且把上面的驱动与文件夹放入刚刚创建好的 aic8800
中。
修改 bsp/drivers/net/wireless/Kconfig
,增加一行
source "bsp/drivers/net/wireless/aic8800/Kconfig"
修改 bsp/drivers/net/wireless/Makefile
,增加一行
obj-$(CONFIG_AIC_WLAN_SUPPORT) += aic8800/
修改 bsp/drivers/net/wireless/aic8800/Kconfig
,修改为 bsp
的索引
if AIC_WLAN_SUPPORT
source "bsp/drivers/net/wireless/aic8800/aic8800_fdrv/Kconfig"
source "bsp/drivers/net/wireless/aic8800/aic8800_btlpm/Kconfig"
endif
if AIC_INTF_USB
source "bsp/drivers/net/wireless/aic8800/aic8800_btusb/Kconfig"
endif
进入内核配置页,找到并勾选如下选项。
[*] Networking support --->
<*> Bluetooth subsystem support --->
[*] Bluetooth Classic (BR/EDR) features (NEW)
<*> RFCOMM protocol support
[*] RFCOMM TTY support
[*] Bluetooth Low Energy (LE) features
[*] Export Bluetooth internals in debugfs
Bluetooth device drivers --->
<*> HCI UART driver
[*] UART (H4) protocol support
-*- Wireless --->
<*> cfg80211 - wireless configuration API
[ ] nl80211 testmode command
[ ] enable developer warnings
[ ] cfg80211 certification onus
[*] enable powersave by default
[ ] cfg80211 DebugFS entries
[*] support CRDA
[*] cfg80211 wireless extensions compatibility
<*> Generic IEEE 802.11 Networking Stack (mac80211)
<*> RF switch subsystem support --->
[*] RF switch input support
<*> GPIO RFKILL driver
Device Drivers --->
Network device support --->
[*] Wireless LAN --->
[*] AIC wireless Support
Enable Chip Interface (SDIO interface support) --->
<M> AIC8800 wlan Support
<M> AIC8800 bluetooth Support (UART)
Misc Devices Drivers --->
<*> Allwinner rfkill driver
<*> Allwinner Network MAC Addess Manager
Linux 5.15 内核设备树
&rfkill {
compatible = "allwinner,sunxi-rfkill";
chip_en;
power_en;
pinctrl-0;
pinctrl-names;
/* wlan session */
wlan {
compatible = "allwinner,sunxi-wlan";
wlan_busnum = <0x1>;
wlan_regon = <&pio PE 6 GPIO_ACTIVE_HIGH>;
wlan_hostwake = <&pio PE 7 GPIO_ACTIVE_HIGH>;
wakeup-source;
/* bt session */
bt {
compatible = "allwinner,sunxi-bt";
bt_rst_n = <&pio PE 8 GPIO_ACTIVE_LOW>;
&addr_mgt {
compatible = "allwinner,sunxi-addr_mgt";
type_addr_wifi = <0x0>;
type_addr_bt = <0x0>;
type_addr_eth = <0x0>;
&btlpm {
compatible = "allwinner,sunxi-btlpm";
uart_index = <0x2>;
bt_wake = <&pio PE 9 GPIO_ACTIVE_HIGH>;
bt_hostwake = <&pio PE 10 GPIO_ACTIVE_HIGH>; /* unused */
wakeup-source;
编译时可以看到生成的对应的 ko 模块
测试
由于 Linux 5.15 不绑定 Tina,所以这里直接使用现成的 debian rootfs
来做测试。
使用上面编译出来的内核与ko驱动,并且将固件放置于 rootfs 对应的 /lib/firmware/
文件夹中
