tmp_摄像头控制接口
V4L2应用程序开发​
1.​
To be able to manipulate the physical properties of a video function, its functionality must be divided into addressable entities. The following two generic entities are identified:
  • Units:Selector Unit 、Processing Unit 、Encoding Unit 、Extension Unit
  • Terminals :Input Terminal (IT) 、Output Terminal (OT) 、Camera Terminal (CT)
  • A Camera Terminal is always represented as an Input Terminal with a single output pin. It provides support for the following features
  • Scanning Mode (Progressive or Interlaced)
  • Auto-Exposure Mode
  • Auto-Exposure Priority
  • Exposure Time
  • Focus
  • Auto-Focus
  • Simple Focus
  • Iris
  • Zoom
  • Pan
  • Roll
  • Tilt
  • Digital Windowing
  • Region of Interest
Controls have attributes, which might include:
  • Current setting
  • Minimum setting
  • Maximum setting
  • Resolution
  • Size
  • Default
Processing Unit
  • User Controls
    • Brightness
    • Hue
    • Saturation
    • Sharpness
    • Gamma
    • Digital Multiplier (Zoom)
  • Auto Controls
    • White Balance Temperature
    • White Balance Component
    • Backlight Compensation
    • Contrast
  • Other
    • Gain
    • Power Line Frequency
    • Analog Video Standard
    • Analog Video Lock Status
Extension Unit
对于每一个entity(IT,PU,SU,OT等)
  • IT: input terminal
  • OT:output terminal
  • VC: video control
video function:含有几个interface,每个video function含有一个VC(video control)、多个VS(video streaming),它们被称为VIC。
https://www.php1.cn/detail/CSS_YangShiGuiZe_218a96fe.html
