DRV_05_I2C接口触摸屏驱动分析
I2C接口触摸屏驱动分析​
  • Linux 5.x内核
    • Documentation/devicetree/bindings/input/touchscreen/goodix.txt
    • drivers/input/touchscreen/goodix.c
  • Linux 4.x内核
    • drivers/input/touchscreen/gt9xx/gt9xx.c
  • 设备树
    • IMX6ULL:Linux-4.9.88/arch/arm/boot/dts/100ask_imx6ull-14x14.dts
    • STM32MP157:Linux-5.4/arch/arm/boot/dts/stm32mp15xx-100ask.dtsi
1. 驱动程序框架​
image-20210331151038656
2. 设备树示例​
2.1 设备树讲解​
示例:
i2c@00000000 {
gt928@5d {
compatible = "goodix,gt928";
reg = <0x5d>;
interrupt-parent = <&gpio>;
interrupts = <0 0>;
irq-gpios = <&gpio1 0 0>;
reset-gpios = <&gpio1 1 0>;
作为一个I2C设备,在某个I2C控制器节点下创建一个子节点。 属性:
  • 必备,根据这个属性找到驱动程序:compatible = "xxxx";
  • 必备,I2C设备地址:reg = <0xXX>;
  • 可选:
    • 中断
  • 复位引脚
2.2 100ASK_IMX6ULL​
&i2c2 {
gt9xx@5d {
compatible = "goodix,gt9xx";
reg = <0x5d>;
interrupt-parent = <&gpio1>;
interrupts = <5 IRQ_TYPE_EDGE_FALLING>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_tsc_reset &pinctrl_touchscreen_int>;
/*pinctrl-1 = <&pinctrl_tsc_irq>;*/
pinctrl-names = "default", "int-output-low", "int-output-high", "int-input";
pinctrl-0 = <&ts_int_default>;
pinctrl-1 = <&ts_int_output_low>;
pinctrl-2 = <&ts_int_output_high>;
pinctrl-3 = <&ts_int_input>;
reset-gpios = <&gpio5 2 GPIO_ACTIVE_LOW>;
irq-gpios = <&gpio1 5 IRQ_TYPE_EDGE_FALLING>;
irq-flags = <2>; /*1:rising 2: falling*/
touchscreen-max-id = <5>;
touchscreen-size-x = <800>;
touchscreen-size-y = <480>;
touchscreen-max-w = <1024>;
touchscreen-max-p = <1024>;
/*touchscreen-key-map = <172>, <158>;*/ /*KEY_HOMEPAGE, KEY_BACK*/
goodix,type-a-report = <0>;
goodix,driver-send-cfg = <0>;
goodix,create-wr-node = <1>;
goodix,wakeup-with-reset = <0>;
goodix,resume-in-workqueue = <0>;
goodix,int-sync = <0>;
goodix,swap-x2y = <0>;
goodix,esd-protect = <0>;
goodix,pen-suppress-finger = <0>;
goodix,auto-update = <0>;
goodix,auto-update-cfg = <0>;
goodix,power-off-sleep = <0>;
2.3 100ASK_STM32MP157​
&i2c4 {
gt911@5d {
reg = <0x5d>;
interrupt-parent = <&gpioe>;
interrupts = <4 IRQ_TYPE_EDGE_FALLING>;
reset-gpios = <&gpioe 12 GPIO_ACTIVE_LOW>;
irq-gpios = <&gpioe 4 IRQ_TYPE_EDGE_FALLING>;
touchscreen-size-x = <1024>;
touchscreen-size-y = <600>;
3. 驱动程序分析​
3.1 分配/设置/注册input_dev​
  • IMX6ULL Linux 4.x
gtp_probe
ret = gtp_request_input_dev(ts);
ts->input_dev = input_allocate_device();
ret = input_register_device(ts->input_dev);
ret = gtp_request_irq(ts);
  • STM32MP157 Linux 5.x
goodix_ts_probe
error = request_firmware_nowait(THIS_MODULE, true, ts->cfg_name,
&client->dev, GFP_KERNEL, ts,
goodix_config_cb);
goodix_config_cb
goodix_configure_dev(ts);
ts->input_dev = devm_input_allocate_device(&ts->client->dev);
error = input_register_device(ts->input_dev);
error = goodix_request_irq(ts);
3.2 注册中断处理函数​
  • IMX6ULL Linux 4.x
ret = request_threaded_irq(ts->client->irq, NULL,
gtp_irq_handler,
ts->pdata->irq_flags | IRQF_ONESHOT,
ts->client->name,
ts);
static int goodix_request_irq(struct goodix_ts_data *ts)
return devm_request_threaded_irq(&ts->client->dev, ts->client->irq,
NULL, goodix_ts_irq_handler,
ts->irq_flags, ts->client->name, ts);
3.3 中断处理函数分析​
通过I2C函数读取数据、上报数据。
  • IMX6ULL Linux 4.x
gtp_irq_handler
gtp_work_func(ts);
point_state = gtp_get_points(ts, points, &key_value);
gtp_i2c_read
i2c_transfer
gtp_mt_slot_report(ts, point_state & 0x0f, points);
input_mt_slot
input_mt_report_slot_state
input_report_abs
goodix_process_events(ts);
touch_num = goodix_ts_read_input_report(ts, point_data);
goodix_i2c_read
i2c_transfer
goodix_ts_report_touch_9b
input_mt_slot
touchscreen_report_pos
input_report_abs
