ROS2环境搭建
1.安装依赖
开始前请注意:如果有进入conda环境,请退出conda环境,执行:conda deactivate
1.添加ROS2 apt仓库
sudo apt install software-properties-common
sudo add-apt-repository universe
2.安装 ROS 2 的密钥和源配置包:
sudo apt update && sudo apt install curl -y
export ROS_APT_SOURCE_VERSION=$(curl -s https://api.github.com/repos/ros-infrastructure/ros-apt-source/releases/latest | grep -F "tag_name" | awk -F\" '{print $4}')
curl -L -o /tmp/ros2-apt-source.deb "https://github.com/ros-infrastructure/ros-apt-source/releases/download/${ROS_APT_SOURCE_VERSION}/ros2-apt-source_${ROS_APT_SOURCE_VERSION}.$(. /etc/os-release && echo $VERSION_CODENAME)_all.deb"
sudo dpkg -i /tmp/ros2-apt-source.deb
3.安装 ROS 2 Jazzy
sudo apt update
sudo apt install ros-jazzy-desktop
4.配置环境变量
每次打开终端时,运行以下命令来加载 ROS 2 环境:
source /opt/ros/jazzy/setup.bash
如果你想让它自动生效,可以将这行添加到你的 ~/.bashrc 文件:
echo "source /opt/ros/jazzy/setup.bash" >> ~/.bashrc
2.验证安装
打开两个终端,分别运行以下命令:
  • 终端1(C++ talker 节点)
ros2 run demo_nodes_cpp talker
  • 终端2(Python listener 节点)
ros2 run demo_nodes_py listener
如果看到消息成功传输,说明安装成功!如下图所示:
image-20250825150924621
