语音识别模型部署
1.模型获取
1.进入语言识别模型目录
cd ~/Projects/rknn_model_zoo/examples/whisper/model
2.下载语音识别模型文件
chmod +x download_model.sh
./download_model.sh
运行效果如下:
(base) baiwen@dshanpi-a1:~/Projects/rknn_model_zoo/examples/whisper/model$ ./download_model.sh
--2025-08-21 10:48:57-- https://ftrg.zbox.filez.com/v2/delivery/data/95f00b0fc900458ba134f8b180b3f7a1/examples/whisper/whisper_encoder_base_20s.onnx
Resolving ftrg.zbox.filez.com (ftrg.zbox.filez.com)... 180.184.171.46
Connecting to ftrg.zbox.filez.com (ftrg.zbox.filez.com)|180.184.171.46|:443... connected.
HTTP request sent, awaiting response... 200
Length: 81395931 (78M) [application/octet-stream]
Saving to: ‘whisper_encoder_base_20s.onnx’
whisper_encoder_base_20s.onnx 100%[==================================================================================>] 77.62M 3.92MB/s in 15s
2025-08-21 10:49:13 (5.06 MB/s) - ‘whisper_encoder_base_20s.onnx’ saved [81395931/81395931]
--2025-08-21 10:49:13-- https://ftrg.zbox.filez.com/v2/delivery/data/95f00b0fc900458ba134f8b180b3f7a1/examples/whisper/whisper_decoder_base_20s.onnx
Length: 313437374 (299M) [application/octet-stream]
Saving to: ‘whisper_decoder_base_20s.onnx’
whisper_decoder_base_20s.onnx 100%[==================================================================================>] 298.92M 5.84MB/s in 47s
2025-08-21 10:50:00 (6.42 MB/s) - ‘whisper_decoder_base_20s.onnx’ saved [313437374/313437374]
下载完成后可以在当前目录下看到whisper_decoder_base_20s.onnx和whisper_encoder_base_20s.onnx
2.模型转换
1.使用Conda激活rknn-toolkit2环境
conda activate rknn-toolkit2
2.进入文字检测模型转换目录
cd ~/Projects/rknn_model_zoo/examples/whisper/python
3.执行模型转换
# 编码器模型
python3 convert.py ../model/whisper_encoder_base_20s.onnx rk3576
# 解码器模型
python3 convert.py ../model/whisper_decoder_base_20s.onnx rk3576
运行效果如下:
(rknn-toolkit2) baiwen@dshanpi-a1:~/Projects/rknn_model_zoo/examples/whisper/python$ python3 convert.py ../model/whisper_encoder_base_20s.onnx rk3576
I rknn-toolkit2 version: 2.3.2
--> Config model
done
--> Loading model
I Loading : 100%|█████████████████████████████████████████████████| 93/93 [00:00<00:00, 1791.34it/s]
W load_onnx: The config.mean_values is None, zeros will be set for input 0!
W load_onnx: The config.std_values is None, ones will be set for input 0!
done
--> Building model
I OpFusing 0: 100%|███████████████████████████████████████████████| 100/100 [00:06<00:00, 14.38it/s]
I OpFusing 1 : 100%|██████████████████████████████████████████████| 100/100 [00:08<00:00, 11.75it/s]
I OpFusing 0 : 100%|██████████████████████████████████████████████| 100/100 [00:11<00:00, 8.72it/s]
I OpFusing 1 : 100%|██████████████████████████████████████████████| 100/100 [00:11<00:00, 8.67it/s]
I OpFusing 2 : 100%|██████████████████████████████████████████████| 100/100 [00:11<00:00, 8.55it/s]
I OpFusing 0 : 100%|██████████████████████████████████████████████| 100/100 [00:11<00:00, 8.37it/s]
I OpFusing 1 : 100%|██████████████████████████████████████████████| 100/100 [00:12<00:00, 8.31it/s]
I OpFusing 2 : 100%|██████████████████████████████████████████████| 100/100 [00:20<00:00, 4.85it/s]
I rknn building ...
I rknn building done.
done
--> Export rknn model
done
(rknn-toolkit2) baiwen@dshanpi-a1:~/Projects/rknn_model_zoo/examples/whisper/python$ python3 convert.py ../model/whisper_decoder_base_20s.onnx rk3576
--> Config model
done
--> Loading model
I Loading : 100%|████████████████████████████████████████████████| 147/147 [00:00<00:00, 255.45it/s]
W load_onnx: The config.mean_values is None, zeros will be set for input 1!
W load_onnx: The config.std_values is None, ones will be set for input 1!
done
--> Building model
W build: For tensor ['/blocks.0/attn/Constant_5_output_0'], the value smaller than -3e+38 or greater than 3e+38 has been corrected to -10000 or 10000. Set opt_level to 2 or lower to disable this correction.
W build: For tensor ['/blocks.0/attn/Constant_5_output_0_1'], the value smaller than -3e+38 or greater than 3e+38 has been corrected to -10000 or 10000. Set opt_level to 2 or lower to disable this correction.
W build: For tensor ['/blocks.0/attn/Constant_5_output_0_2'], the value smaller than -3e+38 or greater than 3e+38 has been corrected to -10000 or 10000. Set opt_level to 2 or lower to disable this correction.
W build: For tensor ['/blocks.0/attn/Constant_5_output_0_3'], the value smaller than -3e+38 or greater than 3e+38 has been corrected to -10000 or 10000. Set opt_level to 2 or lower to disable this correction.
W build: For tensor ['/blocks.0/attn/Constant_5_output_0_4'], the value smaller than -3e+38 or greater than 3e+38 has been corrected to -10000 or 10000. Set opt_level to 2 or lower to disable this correction.
W build: For tensor ['/blocks.0/attn/Constant_5_output_0_5'], the value smaller than -3e+38 or greater than 3e+38 has been corrected to -10000 or 10000. Set opt_level to 2 or lower to disable this correction.
I OpFusing 0: 100%|███████████████████████████████████████████████| 100/100 [00:10<00:00, 9.12it/s]
I OpFusing 1 : 100%|██████████████████████████████████████████████| 100/100 [00:13<00:00, 7.20it/s]
I OpFusing 0 : 100%|██████████████████████████████████████████████| 100/100 [00:18<00:00, 5.34it/s]
I OpFusing 1 : 100%|██████████████████████████████████████████████| 100/100 [00:18<00:00, 5.31it/s]
I OpFusing 2 : 100%|██████████████████████████████████████████████| 100/100 [00:19<00:00, 5.22it/s]
I OpFusing 0 : 100%|██████████████████████████████████████████████| 100/100 [00:19<00:00, 5.02it/s]
I OpFusing 1 : 100%|██████████████████████████████████████████████| 100/100 [00:20<00:00, 4.99it/s]
I OpFusing 2 : 100%|██████████████████████████████████████████████| 100/100 [00:22<00:00, 4.36it/s]
I rknn building ...
E RKNN: [11:58:59.648] Unkown op target: 0
done
done
转换完成后可以在../model/看到生成的RKNN模型文件
(rknn-toolkit2) baiwen@dshanpi-a1:~/Projects/rknn_model_zoo/examples/whisper/python$ ls ../model/
download_model.sh test_en.wav vocab_en.txt whisper_decoder_base_20s.onnx whisper_encoder_base_20s.onnx
mel_80_filters.txt test_zh.wav vocab_zh.txt whisper_decoder_base_20s.rknn whisper_encoder_base_20s.rknn
3.模型推理
1.由于程序需要依赖soundfile库来读取音频文件,所需需要额外执行:
pip install soundfile
2.执行推理程序识别英文:
python whisper.py --encoder_model_path ../model/whisper_encoder_base_20s.rknn --decoder_model_path ../model/whisper_decoder_base_20s.rknn --task en --audio_path ../model/test_en.wav --target rk3576
运行效果:
(rknn-toolkit2) baiwen@dshanpi-a1:~/Projects/rknn_model_zoo/examples/whisper/python$ python whisper.py --encoder_model_path ../model/whisper_encoder_base_20s.rknn --decoder_model_path ../model/whisper_decoder_base_20s.rknn --task en --audio_path ../model/test_en.wav --target rk3576
--> Loading model
done
--> Init runtime environment
I target set by user is: rk3576
done
--> Loading model
done
done
W inference: Inputs should be placed in a list, like [img1, img2], both the img1 and img2 are ndarray.
W inference: The 'data_format' is not set, and its default value is 'nhwc'!
Whisper output: Mr. Quilter is the apostle of the middle classes and we are glad to welcome his gospel.
2.执行推理程序识别中文
python whisper.py --encoder_model_path ../model/whisper_encoder_base_20s.rknn --decoder_model_path ../model/whisper_decoder_base_20s.rknn --task en --audio_path ../model/test_zh.wav --target rk3576
运行效果 如下:
(rknn-toolkit2) baiwen@dshanpi-a1:~/Projects/rknn_model_zoo/examples/whisper/python$ python whisper.py --encoder_model_path ../model/whisper_encoder_base_20s.rknn --decoder_model_path ../model/whisper_decoder_base_20s.rknn --task en --audio_path ../model/test_zh.wav --target rk3576
--> Loading model
done
done
--> Loading model
done
done
Whisper output: I want to say that if you feel interested in my research
4.音频流推理
1.由于需要访问系统设备所以需要退出conda环境,在系统环境下执行:
sudo apt install libportaudio2 portaudio19-dev
运行效果如下:
(base) baiwen@dshanpi-a1:~$ sudo apt install libportaudio2 portaudio19-dev
[sudo] password for baiwen:
正在读取软件包列表... 完成
正在分析软件包的依赖关系树... 完成
正在读取状态信息... 完成
将会同时安装下列软件:
libasound2-dev libjack-jackd2-dev libportaudiocpp0
建议安装:
libasound2-doc portaudio19-doc
下列【新】软件包将被安装:
libasound2-dev libjack-jackd2-dev libportaudio2 libportaudiocpp0 portaudio19-dev
升级了 0 个软件包,新安装了 5 个软件包,要卸载 0 个软件包,有 9 个软件包未被升级。
需要下载 356 kB 的归档。
解压缩后会消耗 1,871 kB 的额外空间。
您希望继续执行吗? [Y/n] y
获取:1 http://ports.ubuntu.com noble-updates/main arm64 libasound2-dev arm64 1.2.11-1ubuntu0.1 [115 kB]
获取:2 http://ports.ubuntu.com noble/main arm64 libjack-jackd2-dev arm64 1.9.21~dfsg-3ubuntu3 [42.9 kB]
获取:3 http://ports.ubuntu.com noble/universe arm64 libportaudio2 arm64 19.6.0-1.2build3 [65.4 kB]
获取:4 http://ports.ubuntu.com noble/universe arm64 libportaudiocpp0 arm64 19.6.0-1.2build3 [16.4 kB]
获取:5 http://ports.ubuntu.com noble/universe arm64 portaudio19-dev arm64 19.6.0-1.2build3 [115 kB]
已下载 356 kB,耗时 3秒 (127 kB/s)
正在选中未选择的软件包 libasound2-dev:arm64。
(正在读取数据库 ... 系统当前共安装有 79465 个文件和目录。)
准备解压 .../libasound2-dev_1.2.11-1ubuntu0.1_arm64.deb ...
正在解压 libasound2-dev:arm64 (1.2.11-1ubuntu0.1) ...
正在选中未选择的软件包 libjack-jackd2-dev:arm64。
准备解压 .../libjack-jackd2-dev_1.9.21~dfsg-3ubuntu3_arm64.deb ...
正在解压 libjack-jackd2-dev:arm64 (1.9.21~dfsg-3ubuntu3) ...
正在选中未选择的软件包 libportaudio2:arm64。
准备解压 .../libportaudio2_19.6.0-1.2build3_arm64.deb ...
正在解压 libportaudio2:arm64 (19.6.0-1.2build3) ...
正在选中未选择的软件包 libportaudiocpp0:arm64。
准备解压 .../libportaudiocpp0_19.6.0-1.2build3_arm64.deb ...
正在解压 libportaudiocpp0:arm64 (19.6.0-1.2build3) ...
正在选中未选择的软件包 portaudio19-dev:arm64。
准备解压 .../portaudio19-dev_19.6.0-1.2build3_arm64.deb ...
正在解压 portaudio19-dev:arm64 (19.6.0-1.2build3) ...
正在设置 libportaudio2:arm64 (19.6.0-1.2build3) ...
正在设置 libjack-jackd2-dev:arm64 (1.9.21~dfsg-3ubuntu3) ...
正在设置 libportaudiocpp0:arm64 (19.6.0-1.2build3) ...
正在设置 libasound2-dev:arm64 (1.2.11-1ubuntu0.1) ...
正在设置 portaudio19-dev:arm64 (19.6.0-1.2build3) ...
正在处理用于 libc-bin (2.39-0ubuntu8.5) 的触发器 ...
2.激活rknn-toolkit2环境
3.让 conda 环境优先使用系统库
cp /usr/lib/aarch64-linux-gnu/libstdc++.so.6 $CONDA_PREFIX/lib/
export LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu:$LD_LIBRARY_PATH
3.安装sounddevice依赖库
pip install sounddevice
4.新建程序文件whisper_mic.py
import numpy as np
from rknn.api import RKNN
import argparse
import soundfile as sf
import onnxruntime
import torch
import torch.nn.functional as F
import scipy
import sounddevice as sd
import queue
import threading
import time
SAMPLE_RATE = 16000
N_FFT = 400
HOP_LENGTH = 160
CHUNK_LENGTH = 20
N_SAMPLES = CHUNK_LENGTH * SAMPLE_RATE
MAX_LENGTH = CHUNK_LENGTH * 100
N_MELS = 80
CHANNELS = 1
q = queue.Queue()
def ensure_sample_rate(waveform, original_sample_rate, desired_sample_rate=16000):
if original_sample_rate != desired_sample_rate:
print("resample_audio: {} HZ -> {} HZ".format(original_sample_rate, desired_sample_rate))
desired_length = int(round(float(len(waveform)) / original_sample_rate * desired_sample_rate))
waveform = scipy.signal.resample(waveform, desired_length)
return waveform, desired_sample_rate
def ensure_channels(waveform, original_channels, desired_channels=1):
if original_channels != desired_channels:
print("convert_channels: {} -> {}".format(original_channels, desired_channels))
waveform = np.mean(waveform, axis=1)
return waveform, desired_channels
def get_char_index(c):
if 'A' <= c <= 'Z':
return ord(c) - ord('A')
elif 'a' <= c <= 'z':
return ord(c) - ord('a') + (ord('Z') - ord('A') + 1)
elif '0' <= c <= '9':
return ord(c) - ord('0') + (ord('Z') - ord('A')) + (ord('z') - ord('a')) + 2
elif c == '+':
return 62
elif c == '/':
return 63
else:
print(f"Unknown character {ord(c)}, {c}")
exit(-1)
def base64_decode(encoded_string):
if not encoded_string:
print("Empty string!")
exit(-1)
output_length = len(encoded_string) // 4 * 3
decoded_string = bytearray(output_length)
index = 0
output_index = 0
while index < len(encoded_string):
if encoded_string[index] == '=':
return " "
first_byte = (get_char_index(encoded_string[index]) << 2) + ((get_char_index(encoded_string[index + 1]) & 0x30) >> 4)
decoded_string[output_index] = first_byte
if index + 2 < len(encoded_string) and encoded_string[index + 2] != '=':
second_byte = ((get_char_index(encoded_string[index + 1]) & 0x0f) << 4) + ((get_char_index(encoded_string[index + 2]) & 0x3c) >> 2)
decoded_string[output_index + 1] = second_byte
if index + 3 < len(encoded_string) and encoded_string[index + 3] != '=':
third_byte = ((get_char_index(encoded_string[index + 2]) & 0x03) << 6) + get_char_index(encoded_string[index + 3])
decoded_string[output_index + 2] = third_byte
output_index += 3
else:
output_index += 2
else:
output_index += 1
index += 4
return decoded_string.decode('utf-8', errors='replace')
def read_vocab(vocab_path):
with open(vocab_path, 'r') as f:
vocab = {}
for line in f:
if len(line.strip().split(' ')) < 2:
key = line.strip().split(' ')[0]
value = ""
else:
key, value = line.strip().split(' ')
vocab[key] = value
return vocab
def pad_or_trim(audio_array):
x_mel = np.zeros((N_MELS, MAX_LENGTH), dtype=np.float32)
real_length = audio_array.shape[1] if audio_array.shape[1] <= MAX_LENGTH else MAX_LENGTH
x_mel[:, :real_length] = audio_array[:, :real_length]
return x_mel
def mel_filters(n_mels):
assert n_mels in {80}, f"Unsupported n_mels: {n_mels}"
filters_path = "../model/mel_80_filters.txt"
mels_data = np.loadtxt(filters_path, dtype=np.float32).reshape((80, 201))
return torch.from_numpy(mels_data)
def log_mel_spectrogram(audio, n_mels, padding=0):
if not torch.is_tensor(audio):
audio = torch.from_numpy(audio)
if padding > 0:
audio = F.pad(audio, (0, padding))
window = torch.hann_window(N_FFT)
stft = torch.stft(audio, N_FFT, HOP_LENGTH, window=window, return_complex=True)
magnitudes = stft[..., :-1].abs() ** 2
filters = mel_filters(n_mels)
mel_spec = filters @ magnitudes
log_spec = torch.clamp(mel_spec, min=1e-10).log10()
log_spec = torch.maximum(log_spec, log_spec.max() - 8.0)
log_spec = (log_spec + 4.0) / 4.0
return log_spec
def run_encoder(encoder_model, in_encoder):
if 'rknn' in str(type(encoder_model)):
out_encoder = encoder_model.inference(inputs=in_encoder)[0]
elif 'onnx' in str(type(encoder_model)):
out_encoder = encoder_model.run(None, {"x": in_encoder})[0]
return out_encoder
def _decode(decoder_model, tokens, out_encoder):
if 'rknn' in str(type(decoder_model)):
out_decoder = decoder_model.inference([np.asarray([tokens], dtype="int64"), out_encoder])[0]
elif 'onnx' in str(type(decoder_model)):
out_decoder = decoder_model.run(None, {"tokens": np.asarray([tokens], dtype="int64"), "audio": out_encoder})[0]
return out_decoder
def run_decoder(decoder_model, out_encoder, vocab, task_code):
# tokenizer = whisper.decoding.get_tokenizer( True, #model.is_multilingual
# task="transcribe",
# language="en",
end_token = 50257 # tokenizer.eot
tokens = [50258, task_code, 50359, 50363] # tokenizer.sot_sequence_including_notimestamps
timestamp_begin = 50364 # tokenizer.timestamp_begin
max_tokens = 12
tokens_str = ''
pop_id = max_tokens
tokens = tokens * int(max_tokens/4)
next_token = 50258 # tokenizer.sot
while next_token != end_token:
out_decoder = _decode(decoder_model, tokens, out_encoder)
next_token = out_decoder[0, -1].argmax()
next_token_str = vocab[str(next_token)]
tokens.append(next_token)
if next_token == end_token:
tokens.pop(-1)
next_token = tokens[-1]
break
if next_token > timestamp_begin:
continue
if pop_id >4:
pop_id -= 1
tokens.pop(pop_id)
tokens_str += next_token_str
result = tokens_str.replace('\u0120', ' ').replace('<|endoftext|>', '').replace('\n', '')
if task_code == 50260: # TASK_FOR_ZH
result = base64_decode(result)
return result
def init_model(model_path, target=None, device_id=None):
if model_path.endswith(".rknn"):
# Create RKNN object
model = RKNN()
# Load RKNN model
print('--> Loading model')
ret = model.load_rknn(model_path)
if ret != 0:
print('Load RKNN model \"{}\" failed!'.format(model_path))
exit(ret)
print('done')
# init runtime environment
print('--> Init runtime environment')
ret = model.init_runtime(target=target, device_id=device_id)
if ret != 0:
print('Init runtime environment failed')
exit(ret)
print('done')
elif model_path.endswith(".onnx"):
model = onnxruntime.InferenceSession(model_path, providers=['CPUExecutionProvider'])
return model
def release_model(model):
if 'rknn' in str(type(model)):
model.release()
elif 'onnx' in str(type(model)):
del model
model = None
def load_array_from_file(filename):
with open(filename, 'r') as file:
data = file.readlines()
array = []
for line in data:
row = [float(num) for num in line.split()]
array.extend(row)
return np.array(array).reshape((80, 2000))
def audio_stream():
"""后台线程:持续把麦克风数据放入队列"""
def callback(indata, frames, time_, status):
if status:
print(status)
q.put(indata[:, 0].astype(np.float32))
with sd.InputStream(samplerate=SAMPLE_RATE,
channels=CHANNELS,
dtype='float32',
callback=callback):
time.sleep(0.1)
def main():
parser = argparse.ArgumentParser(description='Whisper Real-time Mic Demo')
parser.add_argument('--encoder_model_path', required=True)
parser.add_argument('--decoder_model_path', required=True)
parser.add_argument('--task', choices=['en', 'zh'], required=True)
parser.add_argument('--target', default='rk3576')
parser.add_argument('--device_id', default=None)
args = parser.parse_args()
# 准备词典
if args.task == "en":
vocab_path = "../model/vocab_en.txt"
task_code = 50259
else:
vocab_path = "../model/vocab_zh.txt"
task_code = 50260
vocab = read_vocab(vocab_path)
# 初始化 RKNN
encoder_model = init_model(args.encoder_model_path, args.target, args.device_id)
decoder_model = init_model(args.decoder_model_path, args.target, args.device_id)
# 启动麦克风线程
threading.Thread(target=audio_stream, daemon=True).start()
print("Listening... (Ctrl+C to stop)")
# 滑动 20 s 缓存
buffer = np.zeros(N_SAMPLES, dtype=np.float32)
step = SAMPLE_RATE # 1 s 步长
# 每读 1 s 数据就把窗口向前滑动 1 s
data = q.get()
buffer = np.roll(buffer, -len(data))
buffer[-len(data):] = data
# 凑够 20 s 做一次推理
if q.qsize() == 0: # 简单同步:等队列空再做一次,避免堆积
mel = log_mel_spectrogram(buffer, 80).numpy()
mel = pad_or_trim(mel)
mel = np.expand_dims(mel, 0)
out_enc = run_encoder(encoder_model, mel)
txt = run_decoder(decoder_model, out_enc, vocab, task_code)
print("\rWhisper:", txt, end=" " * 10, flush=True)
if __name__ == '__main__':
try:
main()
except KeyboardInterrupt:
print("\nbye")
5.执行程序:
python whisper_mic.py --encoder_model_path ../model/whisper_encoder_base_20s.rknn --decoder_model_path ../model/whisper_decoder_base_20s.rknn --task en --target rk3576
