07_PCI驱动程序框架
PCI驱动程序框架​
开发板资料:
1. PCI驱动框架​
image-20211227180031140
2. RK3399驱动​
怎么找到驱动?
  • 在内核目录下根据芯片名字找到文件:drivers/pci/host/pcie-rockchip.c
    • 看到如下代码:
      static const struct of_device_id rockchip_pcie_of_match[] = {
      { .compatible = "rockchip,rk3399-pcie", },
  • 在内核arch/arm64/boot/dts下搜:grep "rockchip,rk3399-pcie" * -nr
    • 找到设备树文件:arch/arm64/boot/dts/rk3399.dtsi,代码如下:
      pcie0: pcie@f8000000 {
      compatible = "rockchip,rk3399-pcie";
      #address-cells = <3>;
      #size-cells = <2>;
      bus-range = <0x0 0x1f>;
      ...... /* 省略 */
      phys = <&pcie_phy>;
      phy-names = "pcie-phy";
      ranges = <0x83000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000
      0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>;
      reg = <0x0 0xf8000000 0x0 0x2000000>,
      <0x0 0xfd000000 0x0 0x1000000>;
      ...... /* 省略 */
