19_编写console驱动
编写console驱动​
  • 参考代码
    • Linux 4.9.88
      kernel/printk.c
      include/linux/kernel.h
      kernel/printk/internal.h
      drivers/tty/serial/imx.c
    • Linux 5.4
      kernel/printk.c
      kernel/printk/printk_safe.c
      drivers/tty/serial/stm32-usart.
  • 本节视频配套源码在GIT仓库里,目录如下
    doc_and_source_for_drivers\IMX6ULL\source\09_UART\
    08_virtual_uart_driver_console
    doc_and_source_for_drivers\STM32MP157\source\A7\09_UART\
1. 回顾printk的使用​
image-20210813175952791
2. console结构体分析​
include/linux/console.h:
struct console {
char name[16]; // name为"ttyXXX",在cmdline中用"console=ttyXXX0"来匹配
// 输出函数
void (*write)(struct console *, const char *, unsigned);
int (*read)(struct console *, char *, unsigned);
// APP访问/dev/console时通过这个函数来确定是哪个(index)设备
// 举例:
// a. cmdline中"console=ttymxc1"
// b. 则注册对应的console驱动时:console->index = 1
// c. APP访问/dev/console时调用"console->device"来返回这个index
struct tty_driver *(*device)(struct console *co, int *index);
void (*unblank)(void);
// 设置函数, 可设为NULL
int (*setup)(struct console *, char *);
// 匹配函数, 可设为NULL
int (*match)(struct console *, char *name, int idx, char *options);
short flags;
// 哪个设备用作console:
// a. 可以设置为-1, 表示由cmdline=ttyVIRT0确定
// b. 也可以直接指定
short index;
// 常用: CON_PRINTBUFFER
int cflag;
void *data;
struct console *next;
3. 编写console驱动​
* Interrupts are disabled on entering
static void virt_uart_console_write(struct console *co, const char *s, unsigned int count)
int i;
for (i = 0; i < count; i++)
if (txbuf_put(s[i]) != 0)
return;
static struct console virt_uart_console = {
.name = "ttyVIRT",
.write = virt_uart_console_write,
.device = uart_console_device,
.flags = CON_PRINTBUFFER,
.index = -1,
static struct uart_driver virt_uart_drv = {
.owner = THIS_MODULE,
.driver_name = "VIRT_UART",
.dev_name = "ttyVIRT",
.major = 0,
.minor = 0,
.nr = 1,
.cons = virt_uart_console,
4. 上机实验​
4.1 设置工具链​
1. STM32MP157​
export ARCH=arm
2. IMX6ULL​
export ARCH=arm
4.2 编译驱动​
4.3 修改cmdline​
1. IMX6ULL​
在uboot执行:
setenv mmcargs setenv bootargs console=${console},${baudrate} root=${mmcroot} console=ttyVIRT0
boot
启动linux后确认:
cat /proc/cmdline
安装驱动程序:
insmod virtual_uart.ko
cat /proc/consoles /* 确认有没有ttyVIRT0 */
cat /proc/virt_uart_buf /* 查看信息 */
echo hello > /dev/console
2. STM32MP157​
mount /dev/mmcblk2p2 /boot
修改/boot/mmc0_extlinux/和/boot/mmc1_extlinux下的配置文件,
配置文件里的"APPEND"表示cmdline信息,
在"APPEND"行末" console=ttyVIRT0",
在三个"APPEND"语句中都添加
启动linux后确认:
cat /proc/cmdline
安装驱动程序:
