07_SPI_DAC模块上机实验
  • 内核驱动:drivers/spi/spidev.c
  • 内核提供的测试程序:tools/spi/spidev_fdx.c
  • 内核文档:Documentation/spi/spidev
  • DAC芯片手册:TLC5615.pdf
1. 硬件​
1.1 原理图​
IMX6ULL:
image-20220309150927785
STM32MP157:
image-20220309151025637
原理图:
image-20220309151636533
1.2 连接​
1.2.1 IMX6ULL​
DAC模块接到IMX6ULL扩展板的SPI_A插座上:
image-20220309164031109
1.2.2 STM32MP157​
DAC模块接到STM32MP157扩展板的SPI_A插座上:
image-20220311100618477
2. 编写设备树​
确认SPI时钟最大频率:
image-20220309163435541
T = 25 + 25 = 50ns
F = 20000000 = 20MHz
设备树如下:
dac: dac {
compatible = "spidev";
reg = <0>;
spi-max-frequency = <20000000>;
2.1 IMX6ULL​
image-20220311101017666
DAC模块接在这个插座上,那么要在设备树里spi1的节点下创建子节点。
代码在arch/arm/boot/dts/100ask_imx6ull-14x14.dtb中,如下:
&ecspi1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1>;
fsl,spi-num-chipselects = <2>;
cs-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>, <&gpio4 24 GPIO_ACTIVE_LOW>;
dac: dac {
reg = <0>;
2.2 STM32MP157​
image-20220311101127305
DAC模块接在这个插座上,那么要在设备树里spi5的节点下创建子节点。
代码在arch/arm/boot/dts/stm32mp157c-100ask-512d-lcd-v1.dts中,如下:
&spi5 {
pinctrl-0 = <&spi5_pins_a>;
pinctrl-1 = <&spi5_sleep_pins_a>;
cs-gpios = <&gpioh 5 GPIO_ACTIVE_LOW>, <&gpioz 4 GPIO_ACTIVE_LOW>;
spidev: icm20608@0{
compatible = "invensense,icm20608";
interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
interrupt-parent = <&gpioz>;
spi-max-frequency = <8000000>;
reg = <0>;
dac_test: dac_test@1{
reg = <1>;
3. 编译替换设备树​
3.1 IMX6ULL​
3.1.1 设置工具链​
export ARCH=arm
export PATH=$PATH:/home/book/100ask_imx6ull-sdk/ToolChain/arm-buildroot-linux-gnueabihf_sdk-buildroot/bin
3.1.2 编译、替换设备树​
    make dtbs
  • 复制到NFS目录:
  • 开发板上挂载NFS文件系统
  • 更新设备树
    [root@100ask:~]# sync
  • 重启开发板
3.2 STM32MP157​
3.2.1 设置工具链​
export ARCH=arm
3.2.2 编译、替换设备树​
    make dtbs
  • 复制到NFS目录:
  • 开发板上挂载NFS文件系统
  • 确定设备树分区挂载在哪里
    • mmcblk2p2挂载在/mnt目录下(下图右边)
    • mount /dev/mmcblk2p2 /boot
  • 更新设备树
    [root@100ask:~]# cp /mnt/stm32mp157c-100ask-512d-lcd-v1.dtb /boot/
  • 重启开发板
4. 编译spidev驱动​
首先要确定内核中已经含有spidev。在内核目录下执行make menuconfig,查看是否有改驱动,如下图:
-> Device Drivers
-> SPI support (SPI [=y])
< > User mode SPI device driver support
如果User mode SPI device driver support前面不是<Y>或<M>,可以输入M表示把它编译为模块。
  • 如果已经是<Y>,则不用再做其他事情。
  • 如果你设置为<M>,在内核目录下执行make modules,把生成的drivers/spi/spidev.ko复制到NFS目录备用
5. 编译APP​
arm-buildroot-linux-gnueabihf-gcc -o dac_test dac_test.c
6. 上机实验​
如果spidev没有被编译进内核,那么先执行:
insmod spidev.ko
确定设备节点:
ls /dev/spidev*
假设设备节点为/dev/spidev0.0,执行测试程序:
./dac_test /dev/spidev0.0 500
./dac_test /dev/spidev0.0 600
./dac_test /dev/spidev0.0 1000
