09_使用spidev操作SPI_OLED模块
  • 内核驱动:drivers/spi/spidev.c
  • 内核提供的测试程序:tools/spi/spidev_fdx.c
  • 内核文档:Documentation/spi/spidev
  • OLEDC芯片手册:SPEC UG-2864TMBEG01 .pdf、SSD1306-Revision 1.1 (Charge Pump).pdf
  • 所参考的代码在另一个GIT仓库里:https://e.coding.net/weidongshan/01_all_series_quickstart.git
1. 要做的事情​
image-20220314163549210
2. 编写设备树​
无论是使用IMX6ULL开发板还是STM32MP157开发板,都有类似的扩展板。把OLED模块接到扩展板的SPI_A插座上,如下:
image-20220314115446373
2.1.1 IMX6ULL​
DC引脚使用GPIO4_20,不过只需要在APP里直接控制DC引脚,无需在设备树里指定。
设备树如下:
&ecspi1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1>;
fsl,spi-num-chipselects = <2>;
cs-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>, <&gpio4 24 GPIO_ACTIVE_LOW>;
oled: oled {
compatible = "spidev";
reg = <0>;
spi-max-frequency = <10000000>;
2.1.2 STM32MP157​
DC引脚使用GPIOA_13,不过只需要在APP里直接控制DC引脚,无需在设备树里指定。
设备树如下:
&spi5 {
pinctrl-0 = <&spi5_pins_a>;
pinctrl-1 = <&spi5_sleep_pins_a>;
cs-gpios = <&gpioh 5 GPIO_ACTIVE_LOW>, <&gpioz 4 GPIO_ACTIVE_LOW>;
spidev: icm20608@0{
compatible = "invensense,icm20608";
interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
interrupt-parent = <&gpioz>;
spi-max-frequency = <8000000>;
reg = <0>;
oled: oled@1{
reg = <1>;
3. 编写APP​
3.1 怎么控制DC引脚​
查看原理图,确认引脚,然后参考如下文档即可使用APP操作GPIO,假设引脚号码为100,C语言代码如下:
system("echo 100 > /sys/class/gpio/export");
system("echo out > /sys/class/gpio/gpio100/direction");
system("echo 1 > /sys/class/gpio/gpio100/value");
system("echo 0 > /sys/class/gpio/gpio100/value");
system("echo 100 > /sys/class/gpio/unexport");
image-20220314153844190
3.2 基于spidev编写APP​
源码:
image-20220323120846650
