12_编写SPI_DAC模块驱动程序
  • DAC芯片手册:TLC5615.pdf
1. 要做什么事情​
  • 查看原理图,编写设备树
  • 编写驱动程序,注册一个spidrv
  • 编写测试程序
2. 硬件​
2.1 原理图​
IMX6ULL:
image-20220309150927785
STM32MP157:
image-20220309151025637
原理图:
image-20220309151636533
2.2 连接​
2.2.1 IMX6ULL​
DAC模块接到IMX6ULL扩展板的SPI_A插座上:
image-20220309164031109
2.2.2 STM32MP157​
3. 编写设备树​
确认SPI时钟最大频率:
image-20220309163435541
T = 25 + 25 = 50ns
F = 20000000 = 20MHz
设备树如下:
dac: dac {
compatible = "100ask,dac";
reg = <0>;
spi-max-frequency = <20000000>;
3.1 IMX6ULL​
image-20220311101017666
DAC模块接在这个插座上,那么要在设备树里spi1的节点下创建子节点。
代码在arch/arm/boot/dts/100ask_imx6ull-14x14.dtb中,如下:
&ecspi1 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1>;
fsl,spi-num-chipselects = <2>;
cs-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>, <&gpio4 24 GPIO_ACTIVE_LOW>;
dac: dac {
reg = <0>;
3.2 STM32MP157​
image-20220311101127305
DAC模块接在这个插座上,那么要在设备树里spi5的节点下创建子节点。
代码在arch/arm/boot/dts/stm32mp157c-100ask-512d-lcd-v1.dts中,如下:
&spi5 {
pinctrl-0 = <&spi5_pins_a>;
pinctrl-1 = <&spi5_sleep_pins_a>;
cs-gpios = <&gpioh 5 GPIO_ACTIVE_LOW>, <&gpioz 4 GPIO_ACTIVE_LOW>;
spidev: icm20608@0{
compatible = "invensense,icm20608";
interrupts = <0 IRQ_TYPE_EDGE_FALLING>;
interrupt-parent = <&gpioz>;
spi-max-frequency = <8000000>;
reg = <0>;
dac_test: dac_test@1{
reg = <1>;
4. 编写驱动程序​
以前我们基于spidev编写过DAC的应用程序,可以参考它:
image-20220310120532411
5. 编写测试程序​
