10_OLED模块上机实验
  • 内核驱动:drivers/spi/spidev.c
  • 内核提供的测试程序:tools/spi/spidev_fdx.c
  • 内核文档:Documentation/spi/spidev
1. 连接​
1.1 IMX6ULL​
OLED模块接到IMX6ULL扩展板的SPI_A插座上:
1.2 STM32MP157​
OLED模块接到STM32MP157扩展板的SPI_A插座上:
image-20220314171907903
2. 编译替换设备树​
2.1 IMX6ULL​
2.1.1 设置工具链​
export ARCH=arm
export PATH=$PATH:/home/book/100ask_imx6ull-sdk/ToolChain/arm-buildroot-linux-gnueabihf_sdk-buildroot/bin
2.1.2 编译、替换设备树​
  • 修改设备树arch/arm/boot/dts/100ask_imx6ull-14x14.dts
&ecspi1 { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_ecspi1>;
fsl,spi-num-chipselects = <2>; cs-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>, <&gpio4 24 GPIO_ACTIVE_LOW>; status = "okay";
oled: oled { compatible = "spidev"; reg = <0>; spi-max-frequency = <10000000>; }; };
* 编译设备树:
在Ubuntu的IMX6ULL内核目录下执行如下命令,
得到设备树文件:`arch/arm/boot/dts/100ask_imx6ull-14x14.dtb`
```shell
make dtbs
  • 复制到NFS目录:
  • 开发板上挂载NFS文件系统
  • 更新设备树
    [root@100ask:~]# sync
  • 重启开发板
2.2 STM32MP157​
2.2.1 设置工具链​
export ARCH=arm
2.2.2 编译、替换设备树​
  • 修改设备树arch/arm/boot/dts/stm32mp157c-100ask-512d-lcd-v1.dts
&spi5 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&spi5_pins_a>; pinctrl-1 = <&spi5_sleep_pins_a>; status = "okay"; cs-gpios = <&gpioh 5 GPIO_ACTIVE_LOW>, <&gpioz 4 GPIO_ACTIVE_LOW>; spidev: icm20608@0{ compatible = "invensense,icm20608"; interrupts = <0 IRQ_TYPE_EDGE_FALLING>; interrupt-parent = <&gpioz>; spi-max-frequency = <8000000>; reg = <0>; }; oled: oled@1{ compatible = "spidev"; spi-max-frequency = <10000000>; reg = <1>; }; };
* 编译设备树:
在Ubuntu的STM32MP157内核目录下执行如下命令,
得到设备树文件:`arch/arm/boot/dts/stm32mp157c-100ask-512d-lcd-v1.dtb`
```shell
make dtbs
  • 复制到NFS目录:
  • 开发板上挂载NFS文件系统
  • 确定设备树分区挂载在哪里
    • mmcblk2p2挂载在/mnt目录下(下图右边)
    • mount /dev/mmcblk2p2 /boot
  • 更新设备树
    [root@100ask:~]# cp /mnt/stm32mp157c-100ask-512d-lcd-v1.dtb /boot/
  • 重启开发板
3. 编译spidev驱动​
首先要确定内核中已经含有spidev。在内核目录下执行make menuconfig,查看是否有改驱动,如下图:
-&gt; Device Drivers
-&gt; SPI support (SPI [=y])
&lt; &gt; User mode SPI device driver support
如果User mode SPI device driver support前面不是&lt;Y&gt;或&lt;M&gt;,可以输入M表示把它编译为模块。
  • 如果已经是&lt;Y&gt;,则不用再做其他事情。
  • 如果你设置为&lt;M&gt;,在内核目录下执行make modules,把生成的drivers/spi/spidev.ko复制到NFS目录备用
4. 编译APP​
arm-buildroot-linux-gnueabihf-gcc -o spi_oled spi_oled.c
5. 上机实验​
如果spidev没有被编译进内核,那么先执行:
insmod spidev.ko
确定设备节点:
ls /dev/spidev*
执行测试程序:
// IMX6ULL
./spi_oled /dev/spidev0.0 116
// STM32MP157
// 在uboot里GPIOA13被配置为open drain了, 先把它设置为推挽输出
devmem 0x50000a28 32 1; devmem 0x50002004 32 0
./spi_oled /dev/spidev0.1 13
